Program
BIOVIA CISPro
Description
We are providing this Technical Note to inform you about the release of BIOVIA CISPro 2022, which includes the following enhancements and fixed defects:
Enhancements
This release of BIOVIA CISPro includes the following enhancements.
User Story | Description |
CIS-66963 | When opening a grid view, Report Grid fills the scope of the window it displays in. |
CIS-72229 | In CISPro Mobile, added the ability to scan Locked Container Group barcodes as a reconcile operation. |
CIS-73630 | When obsoleting a material with active child containers, a warning is now displayed and active containers must be disposed before the material can be obsoleted. If using the approvals feature, this warning will display before submitting the change request. |
CIS-73932 | Added a new property to Inventory Groups called "Moves Into Group Require Edit Permission". When enabled, this prevents users from moving Containers into Locations of an Inventory Group if they do not have "Edit" permissions. |
CIS-74107 | Renamed the Comments field on the Batch page to "Context". |
CIS-74110 | Added "Registration No" to the Batch page's Scanned Container Details and Dispense History Grid. |
CIS-74172 | Container Groups with Sync Location enabled now have the ability to be marked as "Locked". Locking a Container Group prevents Containers from being moved into or out of the group. In the Inventory API, added the Locked property on Container Groups. |
Fixed Defects
This release of BIOVIA CISPro includes the following fixed defects.
CIS-73628 | When the approvals feature is enabled and materials are set to require approval by default, materials imported from ACD Data Mart will now require secondary review before being added to the system. |
CIS-74189 | Users may no longer create or modify Change Requests while using impersonation. |
CIS-74276 | Resolved security vulnerabilities associated with the web server and application by hiding CISPro Server version details. |
CIS-74283 | Sanitized additional user input when creating Views to prevent malicious activity. |
CIS-74288 | Editing Comment properties using Multi-Edit now appends the new comment to all entities instead of overwriting all comments on subsequent entities with the comments from the edited entity. |
CIS-74307 | Freezer boxes with more than 100 populated coordinates now display all populated cells instead of the first 100. |
CIS-74488 | Editing a CofA will lock the related Receipt Lot if it requires approval. Similarly, editing a Receipt Lot will also lock any CofAs if the Receipt Lot requires approval. |
CIS-68090 | Provided a way to reset all tenant passwords in the CswConfigUX application. |
CIS-71187 | Materials with constituents now correctly synchronize with Ariel regulatory lists regardless of the order in which the material and the regulatory list were created. |
CIS-72600 | The Dispense tab of the Container view shows the link for the context URN which is resolving correctly now. |
CIS-73461 | The "Assign Inventory to Freezers" page no longer fails when searching for freezers if the current user has Receive permission on more than 20 Inventory Groups. |
CIS-73462 | Users will not have the "Transfer from Freezer" option on Request Items "Fulfill" menu if they do not have view and edit container permissions on the requested material. |
CIS-73751 | Added a new tab called "Components" to the "Raw Material" node type. The new tab contains grid properties called "Components" and "All Constituents". |
CIS-73806 | The create material, storage geometries, and mobile kiosk pages load faster. |
CIS-73873 | The Today condition works for CISPro View date filters. |
CIS-73953 | New users created in Foundation Hub sync to CISPro without error when CISPro does not have any Locations which allow inventory. |
CIS-74131 | Obsoleting a record will properly navigate the user to the Change Requests view. |
CIS-74205 | Updated the system configuration so that comment properties are audited by default, and up to 50 comments are stored before old comments are removed. |
CIS-74209 | Fixed an issue allowing changes to be saved without require E-Sig. |
CIS-74229 | When the approvals feature is enabled and a material requires approval, users can now successfully update the supplier by searching for a new value. |
CIS-74265 | Updated the Change Request view to have more filters for reviewing change requests. |
CIS-74266 | Allowed User properties can be edited when synced with Foundation Hub and Requires Approval is enabled on users. |
CIS-74268 | Inventory Group permissions are properly applied to Change Requests for Receipt Lots. Permissions are based on the Inventory Group the Receipt Lot was received into. |
CIS-74281 | Fixed a vulnerability that came from user defined node names. |
CIS-74284 | Fixed a security vulnerability around two API endpoints. Now a user cannot create views for other users or roles if the user does not have the proper nodetype permissions. |
CIS-74285 | Strengthened security around SQL Reports and SQL driven Labels. |
CIS-74347 | Added GHS to the Material's Inventory API endpoint. |
CIS-74489 | Users are no longer able to obsolete materials that have inventory stored in or set to be stored in a freezer. |
CIS-74500 | Open change requests on a user no longer prevent that user from logging in. |
CIS-73058 | "Licensed Inventory" view is removed from the Container section of the View Selector. |
CIS-74116 | "Receipt Lot Expiration Locked" is now available for chemical and material APIs. |
CIS-74340 | When disposing containers stored in freezer boxes using the Inventory API, the system now correctly removes the container from the freezer box. |
CIS-74348 | Lot Certificate's "Approved Until" value now displays time along with date. |
CIS-74532 | Fixed an issue where Change Requests for Users would show changes to properties that are managed by the server. |
Resolution
BIOVIA CISPro 2022 was released in December 2021 and is available for download at https://software.3ds.com/
How to contact BIOVIA Support
If you have any questions, please contact BIOVIA Support.
To view the full TechNote click here.
