CISPro 2021 (T103-2020)
Program
BIOVIA CISPro
Description
We are providing this Technical Note to inform you about the release of BIOVIA CISPro 2021 , which includes the following enhancements and fixed defects:
Enhancements
This release of BIOVIA CISPro includes the following enhancements.
User Story
Description
CIS-71844
 Made minor performance improvements to receiving, create material, unit conversion, mail reports, and custom property logic.
CIS-71912
Change requests now exist in the system for use in the Approvals workflow.
CIS-71913
Creating new entities in the CISPro UI shows the change request.
CIS-71914
Users can access a grid view of their open change requests of entities requiring approval.
CIS-71916
Users can see if an entity is locked due to an open change request, and can access the change request from the locked entity.
CIS-71917
A CISPro user can approve a submitted change request if they are not the creator of that change request.
CIS-71918
When types are configured to require approval, POSTing using the Inventory API creates a change request that must be approved before the entity is created.
CIS-71919
Materials, Inventory Groups, Mail Report Groups, Report Groups, Regulatory Lists, and Regulatory List Permission Profiles get locked when adding, editing, obsoleting, or deleting related entries.
CIS-71920
Add Cancel Approvals Action Permission to allow users to cancel any change request.
CIS-71925
Approvals workflow supports obsoleting/unobsoleting entities.
CIS-72056
Added a new design node property called "Requires Approval" to Design Node Type to be used to configure certain nodetypes to require approvals.
CIS-72058
Prevent disabling Requires Approval on a NodeType with outstanding pending or submitted change requests.
CIS-72063
Added Change Requests to the API. Added Change Request lifecycle actions to the API (Submit, Deny, Approve, Cancel).
CIS-72074
Changes proposed by a change request are available for viewing on the change request in the "Proposed Changes" grid property.
CIS-72075
Added Submitted Change Requests work list report and put it into the view selector.
CIS-72084
Change requests can now be denied from the CISPro UI.
CIS-72091
The creator of a change request can cancel a request if it is not approved yet.
CIS-72092
The creator of a change request can submit a pending change request.
CIS-72100
Updating entities using the Inventory API creates change requests to hold the set of proposed changes.
CIS-72101
The CISPro UI displays change requests when changes are made and the entity requires approval.
CIS-72161
Specific materials can be configured to require approval when making changes.
CIS-72165
When receiving, new receipt lots can be set to require approval before the lot and containers become available to the system.
CIS-72166
Individual receipt lots can be configured to require changes to be approved before they are applied.
CIS-72243
When a change request is approved, the audit history records the proposed changes along with the user who proposed the changes and the user who approved the changes.
CIS-72244
When both approval and an eSignature are required, the prompt to sign for changes now occurs when the user approves the change request.
CIS-72350
Users can edit proposed nodes while they are still pending review.
CIS-72379
Changed button visibility for various different buttons on nodetypes configured to use approvals.
CIS-72503
When approvals is enabled, deleting data must be approved before it is applied to the system.
CIS-68977
Open container is now available in the CISPro Inventory API.
CIS-70465
In-process receipt lots can now be created using the Inventory API.
CIS-67160
Set Quarantined property on Receipt Lots is available out of the box outside of MLM.
CIS-69089
E-signatures can now be enabled for material 'Edit' on regulatory list permission profiles. If material 'Edit' is configured to require e[1]signatures, any receipt lots and documents (including material documents, SDS documents and CofA documents) of that material will also require e-signatures on edit.
CIS-69124
Added CofA Documents to the Inventory API.
CIS-69283
Unentered or rejected Results can now be unassigned.
CIS-69439
Added SAP Number and Material Category to Material Inventory API Model.
CIS-69898
Improved the performance of the /Certificates/Initialize endpoint.
CIS-69900
Improved the performance of the /Certificates/GetExpectedSampleQuantity endpoint.
CIS-69901
Improved the performance of the /Certificates/GetCertificateMethods endpoint.
CIS-69902
Optimized the performance of the /Certificates/GetMethodTestingLabs endpoint.
CIS-69993
Ability to create, retrieve, and modify WorkUnits is now available in the Inventory API.
CIS-69997
When existing users are marked as Obsolete or Archived, or a user is deleted in Foundation Hub, that user's information is removed from the permission_group_permissions.
CIS-70556
Quantity confirmed and unconfirmed receipt lots now have a button for printing reserved barcodes to an EPL printer.
CIS-70922
Request comments keep displaying throughout the dispensing phase of request fulfillment using Mobile apps.
CIS-71027
Added External Document ID and Provider to the SDS Documents Inventory API endpoint.
CIS-71128
Added GHS Classifications endpoint to the Inventory API.
CIS-71129
Added GHSPhrases endpoint to the Inventory API.
CIS-71313
Add Internal to the Vendor Property Set. Only allow Create Batch button to be visible on a material who's supplier is marked internal.
CIS-71696
All materials are now capable of having SDS documents added, supporting all SDS features except for third party SDS providers.
CIS-71848
The Received Registration Number property options are now filtered down to the Received Registration Numbers from the receipt lots dispensed into the batch.
CIS-71909
Environments running ODAC 19c are now supported, with additional instructions during installation.
CIS-71924
Request Item can now be provided to Inventory API endpoints /DispenseToChild and /DispenseToChildWithSize in order to associate a container dispense with a request.
CIS-72020
The Inventory API Receiving endpoint now supports Guids for Location, Owner and Size.
CIS-72103
Updated color scheme to align with official Dassault Systèmes color palette.
Fixed Defects
This release of BIOVIA CISPro includes the following fixed defects.
User Story
Description
CIS-71736
Property References to Date props now display correct dates.
CIS-71823
Removed erroneous timestamp from Dispense Wizard landing page title.
CIS-72005
customProperties can now be used with the \\\$expand query parameter when using the Inventory API.
CIS-72576
Auto-fill quantity per each values when dispensing containers with quantity per each values to child containers in Mobile Kiosk Dispensing.
CIS-72739
Removed sensitive session data to prevent malicious session hijacking.
CIS-72894
Fixed an issue preventing non-administrator users from creating Batch Requests.
CIS-65610
The system now prevents users from assigning certificates of the same certificate definition family (all versions are included) and level to the same receipt lot unless the prior certificate is in a terminal state (cancelled, approved, or rejected).
CIS-66729
When copying batch requests, Container Group is blank on the new batch requests.
CIS-66923
Results Entry search by Receipt Lot, Sample, and Method is now case insensitive.
CIS-69334
Users using the Add to Batch request are now prevented from selecting inventory groups that they do not have request permission on.
CIS-69402
In an environment with PCID Sync enabled, when importing from ACD Data Mart with the Create Material Page, ACD Data Mart GHS data now takes precedence over PCID GHS data.
CIS-70941
Mail reports are no longer sent to obsolete users.
CIS-71264
Fixed an issue that would cause val_kg and val_L columns to both contain data when changing quantity units between mass and volume.
CIS-71406
Fixed an issue where adding a new material component to a material would clear Ariel managed regulatory list membership.
CIS-71460
Fixed an issue that would prevent users from being able to log in if a user with the same username existed but was obsoleted.
CIS-71856
Fixed an issue preventing \\\$bulk creation of Users in the Inventory API.
CIS-71875
On the Mobile Kiosk Verification page and the Inventory API Verify Quantity Endpoint, users cannot verify negative quantities.
CIS-71937
Duplicate data is no longer created when importing products from ACD Data Mart with the Create Material Page.
CIS-71941
Users with view inventory group permissions but no edit permissions are no longer able to move containers with the Logistics page.
CIS-72218
Use day, month, and year, rather than just year to determine max value of when to hide date values.
CIS-72285
The Language field of users sync'd from Foundation Hub now default to English unless an existing default is set.
CIS-72391
Reconciliation scan times are now properly respect the user's local time zone.
CIS-72562
Containers that are created using a Batch operation no longer have incorrect expiration dates by default.
CIS-72584
Look for and generate more generic sizes when receiving using the Inventory API.
CIS-72665
Fixed an issue that would prevent some values on Mobile Kiosk from displaying when browser Language was set to a language other than English.
CIS-72741
New users have create and edit permissions on Report nodes disabled by default.
CIS-72929
Fixed an issue with the Create Material wizard where sizes were failing to import when importing materials from ACD Data Mart.
CIS-72944
Fixed an issue preventing dispensing from Containers with 0 Quantity in Mobile Kiosk.
CIS-72945
Fixed an issue that would cause context not to be saved when dispensing to child containers.
CIS-72957
Fixed an issue where location sync did not properly match locations in CISPro with locations in Foundation Hub.
CIS-72826
The History grid now indicates that BeforeValues and AfterValues of type Date are in Coordinated Universal Time (UTC).
Resolution
BIOVIA CISPro 2021 was released in December 2020 and is available for download at https://software.3ds.com/
How to contact BIOVIA Support
If you have any questions, please contact BIOVIA Support.
To view the full TechNote click here.
