Program
BIOVIA CISPro
Description
We are providing this Technical Note to inform you about the release of BIOVIA CISPro 2021 Service Pack 2, which includes the following enhancements and fixed defects:
Enhancements
This release of BIOVIA CISPro includes the following enhancements.
User Story | Description |
CIS-73528 | Added a new worklist for managing Change Requests. |
CIS-73188 | Added enforce_storage_compatibility configuration variable if enabled, when trying to assign a container to a location with mismatched storage compatibility, the assignment is prevented. |
CIS-73084 | Highlighting cells will now display details in an "Additional Details" panel. |
CIS-69906 | Improved performance when adjusting time and location scope in the Reconciliation wizard. |
CIS-69907 | Improved performance when loading Step 2 of the Reconciliation wizard. |
CIS-71007 | MLM: In the mobile app, when dispensing and printing labels with MLM module, the last container dispensed is selected by default for printing. |
CIS-71879 | MLM: Container Quantity is now displayed on the containers grid for the Mobile Retrieval workflow. |
CIS-71240 | MLM: Prevent approved Certificate Definitions from reverting back to non-approved state. |
CIS-72387 | MLM: The certificate status of each container displays in the Mobile Retrieval's container list when the request is against a certificate level. |
CIS-72380 | MLM: The certificate status of the scanned container is now displayed on the Mobile Retrieval screen. |
CIS-72382 | MLM: The certificate status of the scanned container now displays on the mobile Dispensing screen when the request is against a certificate level. |
CIS-73020 | MLM: Users dispensing Material with the CISPro Mobile Dispense page can view the primary SDS Document for the Container being dispensed. |
CIS-72247 | MLM: Users may assign Certificates to child Containers during dispensing. |
CIS-72645 | New schema will prevent users from enabling deprecated approvals features. |
CIS-68910 | NFPA diamond in CISPro's UI displays the label "Instability" instead of "Reactivity" for the yellow diamond. |
CIS-71506 | Receipt Lots can now be configured to manage the expiration date of all containers using the Expiration Locked property on Receipt Lots and Receipt Lot Expiration Locked property on Materials. |
CIS-72466 | Receipt Lots with inventory stored in freezer boxes now include a grid that displays how much inventory is stored in freezers and what freezer box the inventory is in. This grid also includes a way to navigate directly from the grid to the freezer box(s) containing the inventory. |
CIS-70829 | Removed "Export Configuration" from "Admin" drop down menu. |
CIS-73175 | Reports now additionally have the option to be ran and downloaded as Excel files. |
CIS-71041 | Selected preferred suppliers display first in the list of preferred suppliers when searching Data Mart. |
CIS-73215 | The CISPro Login page and the CISPro favicon have been updated to the display the new version of the BIOVIA logo. |
CIS-70117 | The reconciliation rule now sends an email and logs an error instead of going reprobate when a bad move reconciliation is attempted. |
CIS-72851 | Users are now notified that changes are saved when "Save Changes" button is pressed. |
CIS-71881 | Users can now cancel all request items under a Request that are marked "staged" or "submitted" using a button on the Request itself, which will ask for a reason. |
CIS-68930 | Users now have the ability to set unscanned containers to be disposed during reconciliation. |
CIS-59378 | When a user dispenses or transfers a container that is marked missing, the missing tag is removed and the user is alerted. |
CIS-66731 | When running the automated installer to upgrade CISPro, if system level database credentials and a valid TNS name are provided, all necessary grants will be run on the CISPro schema. |
Fixed Defects
This release of BIOVIA CISPro includes the following fixed defects.
CIS-73689 | Users will not be able to modify Change Request once it is Submitted. |
CIS-73767 | Fixed a bug in receiving that would sometimes cause expiration intervals to set the time of an expiration date to something other than a second before midnight. |
CIS-73471 | Fixed a bug that was causing imported history from CAF to not appear in the history grid. |
CIS-73916 | Fixed a bug that would prevent receiving when batch components were too small. |
CIS-73511 | Fixed a bug that would prevent users from receiving when manufactured date was set to today for users east of GMT. |
CIS-73816 | Fixed an issue where approving a change request for new containers did not set their location properly. |
CIS-73664 | Fixed an issue where approving changes to Material could incorrectly change the Next Receipt Lot No field. |
CIS-73862 | Fixed an issue where Receipt Lots "Received Registration No" property would not be marked as required in the Receive page in some circumstances. |
CIS-73718 | Fixed an issue where the PurgeSessionData rule would mistakenly deleted un-approved changes. |
CIS-73783 | It is possible to add a C of A (Certificate of Analysis) document as a link during receiving. |
CIS-73742 | MLM: When the approval period on a certificate spans DST (i.e, starts in non-DST and ends in DST or viceversa) the time-stamp on the Approved Until value is now set to the end of the day (11:59:59) local time. |
CIS-73749 | MLM: Whenever a user attempts to cancel a Result, if cancelling that Result would leave any Certificate it is associated with without at least one entered Result (ie. a Result with a status of Pending, Completed, Rejected, or Submitted), the system prevents the Result from being cancelled and displays a warning message to the user. |
CIS-73750 | Report driven grids now support using the ClientUtcOffset. |
CIS-73206 | When dispensing a non-each Biological container, the UOM options now include volume and mass options. |
CIS-73156 | Fixed bug when vendor approvals are required. |
CIS-70333 | At the server-level we prevented deletion of storage units if the storage unit currently has inventory and prevented deletion of racks if any of the storage units in the rack have inventory. |
CIS-69925 | Canceling individual request items now pops a dialog with space for a comment, instead of requiring the user to be editing the node with a comment written in and unsaved. |
CIS-72768 | Containers dispensed against a "Pending" certificate will inherit expiration date from Receipt Lot. |
CIS-72769 | Containers dispensed against a "Pending" certificate, and has container status of "See Dispensing Certificate" will remain as "See Dispensing Certificate" after certificate approval. |
CIS-72879 | Design mode users will not be able to delete the only remaining NodeType. |
CIS-72040 | Fixed a bug that prevented users from adding Mobile Kiosk links to the welcome page. |
CIS-72893 | Fixed an issue where merging two Materials could generate an error in some circumstances if they belonged to a Regulatory List. |
CIS-73976 | Fixed an issue where the change request worklist would not prompt for esignature on new receipt lots. |
CIS-73294 | Fixed an issue where users could assign barcodes that duplicated existing un-approved containers. |
CIS-72740 | Fixed an issue where users could view data they were not permitted to. |
CIS-72834 | Fixed bug to prevent users from adding duplicate Batch Ids. |
CIS-73218 | Fixed number rounding bug when dispensing containers with mobile kiosk. |
CIS-65910 | Installer will allow to install CISPro to a folder containing a space. |
CIS-73972 | Newly received Tier II Containers now display on the Tier II Reporting grid as expected. |
CIS-65901 | Removed Firewall check as it's not relevant. That was used to see if the legacy PCID and FireDB data location can be reached - but this is no longer used. |
CIS-73571 | Users are prevented to access Design Mode from Design Nodes. |
CIS-73772 | When recalculating the Expiration Date by setting a Manufactured Date in receiving,the time is properly set to 11:59:59 PM. |
CIS-70724 | Added information to the Security section of the installation guide on how to set up Content-Security-Policy headers. |
CIS-67615 | As newer versions of Oracle (18c+) changed the install path to no longer contain an "odac_64"/"odac_32" directory, we removed this check from our installation wizard to make it more user friendly. |
CIS-73078 | Copyright year for BIOVIA CISPro Log Service and BIOVIA CISPro Schedule service will now include the current year. |
CIS-72742 | Custom error page is available in case of error to hide implementation details and make CISPro more secure. |
CIS-73915 | Fixed an issue where grids would not display dates in the user’s timezone. |
CIS-70096 | Floor and Lab Location types from Hub will be assigned first found Inventory Group in CISPro. |
CIS-73488 | For Request Material by Bulk or Request Material by Size, the Receipt lot to dispense dropdown scope for the receipt lots of that material only. However, there is an exception for storage unit receipt lots where Receipt lot to dispense dropdown scope to non-storage unit receipt lots for Request Material by Bulk requests. |
CIS-73245 | Properly provide the user with feedback when they scan an invalid barcode during Container Store operation in Storage Geometries. |
CIS-61892 | Renamed button labels from 'Complete Request' to 'Mark Complete'. |
CIS-73971 | Updated the "Configuring CISPro for use with Foundation Hub" section of the Installation Guide to include details around proper syncing of User and Location data between CISPro and Hub. |
CIS-73447 | Users can now create additional Sites without error. |
CIS-73973 | When using the Reconciliation wizard, selecting the 'View Reconcile Locations without scans' link will now display the correct unscanned locations. |
Resolution
BIOVIA CISPro 2020 Service Pack 2 was released in June 2021 and is available for download at https://software.3ds.com/
How to contact BIOVIA Support
If you have any questions, please contact BIOVIA Support.
To view the full TechNote click here.
