Program
BIOVIA CISPro
Description
We are providing this Technical Note to inform you about the release of BIOVIA CISPro 2021 Service Pack 2 Hot Fix 1, which includes the following enhancements and fixed defects:
Enhancements
This release of BIOVIA CISPro includes the following enhancements.
User Story | Description |
CIS-74166 | Fixed an issue preventing CISPro from using connection pooling. |
CIS-73179 | When the ULM lot certification functionality is enabled, Lot Certificates can be created in CISPro. |
CIS-74128 | As part of the ULM lot certification functionality, assigning Lot Certificates to Receipt Lots in CISPro links the Certificate in Hub to the Lot Certificate in CISPro. |
CIS-74019 | Added 'lot_certification' configuration variable to enable lot certification workflows. |
CIS-73776 | When the ULM lot certification functionality is enabled, users are able to view the CofA document associated with a Hub Certificate from the corresponding CISPro Lot Certificate. |
CIS-73296 | When the ULM lot certification functionality is enabled, as a Certificate changes in the Hub, the corresponding Lot Certificate in CISPro is updated accordingly. |
CIS-73180 | When the ULM lot certification functionality is enabled, users have the ability to assign Material Specifications from Hub to Materials in CISPro. |
CIS-73170 | When the ULM lot certification functionality is enabled, users can now assign Lot Certificates to CISPro Receipt Lots which will automatically generate a Hub Certificate and a Task Plan with Tasks and Samples according to a particular Hub Specification. |
Fixed Defects
This release of BIOVIA CISPro includes the following fixed defects.
CIS-73637 | Fixed an issue where users sessions could persist longer than they should. |
CIS-74292 | Dates and times displayed in Cispro grids are displayed in the user's local time zone. |
CIS-73553 | In case of hub authentication also, role related operations are possible without any error. Now user can create, edit, delete or obsolete role. |
CIS-74356 | Containers touched or scanned prior to the Reconciliation start date are counted as Not Scanned on the Reconciliation Statistics grid. |
CIS-74311 | Date/time values displayed in CISPro grids correctly display time values in the user's time zone. |
CIS-69998 | If a permission group is deleted (for example an Inventory Group is deleted) then it will also be deleted from PERMISSION_GROUP_PERMISSIONS |
CIS-73988 | Made custom comment properties function more in line with out of the box comment properties when providing values via the Inventory API. |
CIS-74238 | The reconciliation wizard now correctly selects all container reconciliation scans in the selected range of dates, using the users current time zone. Additionally, the date displayed on the final step's grid correctly displays the date in the users time zone. |
CIS-74210 | Attempting to expand fields in the Mobile Viewer no longer leads to an error that logs the user out. |
CIS-68547 | The "+New" button should be hidden from user without the proper NodeType permission. |
Resolution
BIOVIA CISPro 2021 Service Pack 2 Hot Fix 1 was released in August 2021 and is available for download at https://software.3ds.com/
How to contact BIOVIA Support
If you have any questions, please contact BIOVIA Support.
To view the full TechNote click here.
