CISPro 2021 SP1 (T38-2021)
Program
BIOVIA CISPro
Description
We are providing this Technical Note to inform you about the release of BIOVIA CISPro 2021 Service Pack 1, which includes the following enhancements and fixed defects:
Enhancements
This release of BIOVIA CISPro includes the following enhancements.
User Story
Description
CIS-65037
Move requests can now be created on containers whether in a central inventory group or not.
CIS-66506
Request Material Create no longer requires a quantity.
CIS-67690
Users now have access to an Open mobile kiosk page, with the full usability of the Open kiosk option. Additionally, a new permission has been added for Open (mobile kiosk) which is enabled by default, allowing users to see Open in the view selector and visit the page.
CIS-68031
Improve the user experience when requesting a Move, Dispose or Dispense on a Container. Users now have the option to immediately submit the request, or add it to the cart.
CIS-68564
Added Requestor, Delivery Location, & Container Location columns to Request Queue.
CIS-69393
Users can now fulfill requests for in-process receipt lots with inventory stored in freezer boxes.
CIS-71167
Containers stored in freezers have a link to the freezer page that will also highlight the specific cell it's in.
CIS-71601
Users are now able to delete pending requests from the requesting cart, regardless of delete permissions.
CIS-72227
Added a new page to the Mobile Kiosk application which allows users with permission to add and remove Containers from Container Groups.
CIS-72286
When verifying quantity on the dispense or container verification page, now specifies whether Net or Gross quantity is being verified against.
CIS-72361
Removed requirement to provide Owner or Location when using Container Verification Mobile Kiosk page.
CIS-72362
The container verification page now has a Context field. Filling in the context field will set the context on the created dispense.
CIS-72539
Container groups that have containers assigned cannot be obsoleted, and the option to do so is removed from the options drop down.
CIS-72991
Allow administrators to enable or disable esignature requirements on Mobile Kiosk Dispense and Verification pages by dispense type.
CIS-73091
Improve the user experience when requesting a Material by Size or Bulk. Users now have the option to immediately submit the request, or add it to the cart.
CIS-73109
Added the ability for users to Request specific Receipt Lots and Manufacturer Lot No's.
Fixed Defects
This release of BIOVIA CISPro includes the following fixed defects.
User Story
Description
CIS-73572
Prevent users from being able to create inventory from the batch page if no dispenses are recorded.
CIS-73537
Report-driven grid properties with userid and/or nodeid parameters can now be exported to CSV from the More > Export >CSV menu of the grid property regardless of the case of the parameters.
CIS-73258
Scanning an invalid barcode when transferring inventory from a freezer box displays an error message in a dialog.
CIS-73445
Scans uploaded using Legacy Mobile Data or Mobile Reconciliation are now available immediately, instead of the next calendar day.
CIS-71991
Added timestamps to Expiration Date on Mobile Kiosk pages.
CIS-73094
Being logged out of CISPro from Mobile no longer returns the user to an old, non-functional login page, and instead routes to the expected login.
CIS-72865
Fixed a usability issue where users had partially type an esig reason before they could select one from a drop down.
CIS-73056
Fixed an issue where creating Documents would generate an error if Approvals was enabled.
CIS-70714
Fixed bug in the design \\\$form API that would cause the Quantity value of Quantity Props to show as required when the property was marked Quantity Optional.
CIS-73036
Fixed Vectors prop on Biologicals where it was defined as a MultiList prop rather than a Text prop.
CIS-72583
Freezer cells with a known barcode no longer display the size information.
CIS-71642
New schema will have the Manufacturer Lot Info module enabled by default.
CIS-73577
Submitting Request Items maintains the selected Inventory Group and Delivery Location defined on the Request Cart page.
CIS-73374
Unit Conversion logic no longer considers obsolete units.
CIS-69211
Updated print client documentation to clarify how to remove disabled printers from the printer list.
CIS-73142
Updated the Mobile Kiosk Dispense page so that all of the container information displays on supported devices with smaller resolutions.
CIS-72660
Updated the System Requirements guide to include Windows 10 under the list of supported operating systems for the CISPro Print Client.
CIS-73289
Updated the System Requirements guide to remove outdated ODAC note.
CIS-71981
Add a new size during receipt now displays the correct quantity fields when the use_gross_weight configuration variable is enabled.
CIS-72666
Improve error messages on Mobile Kiosk page.
Resolution
BIOVIA CISPro 2021 Service Pack 1 was released in March 2021 and is available for download at https://software.3ds.com/
How to contact BIOVIA Support
If you have any questions, please contact BIOVIA Support.
To view the full TechNote click here.
