Program
BIOVIA CISPro
Description
We are providing this Technical Note to inform you about the release of BIOVIA CISPro 2021 Hot Fix 1, which includes the following enhancements and fixed defects:
Enhancements
This release of BIOVIA CISPro includes the following enhancements.
User Story | Description |
CIS-72205 | Now displays the user’s time zone in the history grid disclaimer. |
CIS-72841 | Users can now utilize the "clientutcoffset" parameter in SQL reports to perform date/time calculations. If this parameter is used in a report run via the CISPro UI, it will automatically be replaced with the client's UTC offset value (e.g. -05:00). When executing reports with this parameter via the Inventory API, the consumer must provide the UTC offset. The UTC offset should be formatted as: +/-00:00. |
CIS-73116 | API users can receive new lots and optionally submit the change request in a single web service call. |
Fixed Defects
This release of BIOVIA CISPro includes the following fixed defects.
CIS-72840 | Users can now utilize the "clientutcoffset" parameter in the SQL for Print Labels to perform date/time calculations. If this parameter is used in a print label run via the CISPro UI, it will automatically be replaced with the client's UTC offset value (e.g. -05:00). When printing labels with this parameter via the Inventory API, the consumer must provide the UTC offset. The UTC offset should be formatted as: +/-00:00. |
CIS-73125 | Fixed an issue with the Inventory Request page in which the available inventory was including containers that were not in the selected inventory group. |
CIS-73127 | Fixed an issue with the Inventory Request page in which the available inventory was including freezer inventory that was not in the selected inventory group. |
CIS-73143 | Fixed an issue where the session expiration popup would appear too frequently when roles had short expiration intervals. |
CIS-73165 | Fixed an issue when CISPro was registered with Hub where users got an error when editing Receipt Lots. |
CIS-70182 | Fixed a bug that would prevent searching for items with special characters in Mobile Kiosk and Storage geometries. |
CIS-70286 | Exporting a grid property to CSV no longer fails when the grid property is driven by the current users ID. |
CIS-71279 | Grids opened in dialogs now properly support Export to CSV functionality. |
CIS-72309 | Receiving via the Inventory API now supports returning custom Receipt Lot and Container properties. |
CIS-72720 | Prevented superuser from editing Server Managed properties. |
CIS-72774 | The option to create new vendors or constituents on the Create Material page is removed when the respective node types require approval. This does not apply to request fulfillment or ACD imports. |
CIS-72858 | Receiving containers via the receive page and creating a material via the create material page honor default values set in design mode for the "Requires Approval" property. |
CIS-72861 | Navigating from CISPro to CISPro Mobile via the "Preferences > Use Mobile" option no longer causes the add location button in the Reconciliation action to fail. |
CIS-72870 | Comments are no longer duplicated on Change Requests when approved. |
CIS-72877 | Racks are now created and edited without clearing the freezer_id. |
CIS-72911 | The Inventory Request page search now returns results when the manufacturer lot number search has a '#' in the value. |
CIS-72912 | Manage Inventory button on receipt lot now correctly filters data on the Freezer Inventory page when the manufacturer lot number has a '#' character in the value. |
CIS-72980 | Barcode searches in Mobile Kiosk Container Logistics are no longer case-sensitive. |
CIS-73049 | Users are no longer able to create a new size or SDS during receiving when the material requires approval. |
CIS-73064 | The ability to approve and deny change requests now require the user to have both create and edit permissions on the changed node type. |
CIS-73098 | Barcode fields in Storage Geometries are no longer case sensitive. |
CIS-73115 | Editing an existing record to make it require approval will create a change request that must be approved before the edit is applied. |
CIS-73117 | Updated the error message when attempting to receive a lot that requires approval when the material does not require approval to be more clear. |
CIS-73158 | The create new manufacturer button is now unavailable during a receive when Manufacturers require approval. |
CIS-72389 | Fixed an issue where node names would not immediately update after changing property values. |
CIS-73028 | The "Requires Approval" property will only display during receiving if the material being received requires approval. |
Resolution
BIOVIA CISPro 2021 Hot Fix 1 was released in February 2021 and is available for download at https://software.3ds.com/
How to contact BIOVIA Support
If you have any questions, please contact BIOVIA Support.
To view the full TechNote click here.
