Program
BIOVIA CISPro
Description
We are providing this Technical Note to inform you about the release of BIOVIA CISPro 2020 Hot Fix 1, which includes the following enhancements and fixed defects:
Enhancements
This release of BIOVIA CISPro includes the following enhancements.
User Story | Description |
CIS-70423 | Added the ability to click and drag a range of cells to select them in the storage geometries application. |
CIS-70265 | Added the ability to visualize a box on the Assign Locations page, rearrange its contents, and select specific cells to place inventory into |
CIS-70542 | Clicking on the manufacturer lot number from a freezer in storage geometries navigates to the receipt lot in a new tab. |
CIS-70164 | Freezer Inventory user can now relocate all contents (boxes, racks, and the inventory contained in them) to a freezer that has not been configured yet. |
CIS-70627 | Users can now use the Move operation in storage geometries to move containers of multiple receipt lots, instead of one distinct lot at a time. |
Fixed Defects
This release of BIOVIA CISPro includes the following fixed defects.
CIS-70992 | Added document_file_format_whitelist Configuration Variable for administrators to restrict file uploads to only specific file types. |
CIS-71092 | CISPro users must now have both View on the Report type and View on the related Report Group to view and run reports. |
CIS-71095 | Entity preview dialog title now sanitized to prevent XSS. |
CIS-70933 | ExtChemDataSync rule now sets the version on all Chemicals and Constituents that have been processed regardless of whether they are part of an Ariel Managed Regulatory List. |
CIS-68524 | Performance of api/v1/Sampling/ScanAndVerify was improved by substituting Tree Loader queries with SQL queries. |
CIS-69828 | Performance of Sampling/Collect Endpoint was improved by replacing Tree Loader queries with SQL queries. |
CIS-70925 | The piece of code possibly providing a way to inject OS Commands has been removed. |
CIS-70561 | All datetime view filters now use the same datetime format (including both local and UTC filters). |
CIS-71137 | Container Verification page will load container information of the scanned containers correctly on the first scan as well. |
CIS-70784 | Containers received today now display in the Reconciliation wizard. |
CIS-71031 | Downloading the Print and/or Balance client now correctly updates the corresponding configuration variable value. |
CIS-71084 | Fixed an issue where the 'Reserved Barcode' report may have been created as an "IMCS Report" instead of a "Report" type. |
CIS-70947 | Fixed issue with Home button sometimes being unavailable. Home button is now additionally available on the SDS viewer page, and will navigate user to the login page. |
CIS-71038 | Options for relationship props used on Receive page won't be cached as a part of the ReceiptDefinition property on Receipt Lots anymore. |
CIS-70991 | Removed dependency on session token cookie and session token in the query string parameters from CISPro and CISPro Mobile. |
CIS-70760 | The ExpiredContainer rule now expires containers based on the correct time, instead of being off by UTC - current time zone |
CIS-70759 | Upon editing and saving the expiration date and time on a container, expiration status is based off of current time instead of only date. |
CIS-70497 | Fixed missed date and time localization in Kiosk Mode and SQL driven grids. |
CIS-71062 | Obsoleted freezer locations no longer display in the freezer search when the location name matches a valid location. |
Resolution
BIOVIA CISPro 2020 Hot Fix 1 was released in January 2020 and is available for download at https://software.3ds.com/
How to contact BIOVIA Support
If you have any questions, please contact BIOVIA Support.
To view the full TechNote click here.
