[SOLIDWORKS] SOLIDWORKS Turning Professional
- Support shop floor operator by delivering a NC Documentation that is flexible and easy to customize.
- Increase usability with compare toolpath function to evaluate modifications between releases and while changing key parameters.
- Increase flexibility and efficiency of sequential axial operation simplifying selection of bottom and top and adding circular motion.
I
Support the shop floor operator by delivering an NC Documentation that is flexible and easy to customize. Generate NC documentation, define pictures, and customize the output using XML and/or HTML format.
I
Easily compare toolpaths using the multi-view mode to evaluate modifications between releases and when changing key parameters. Compare two machining activities, the same activity after a force computation during a release migration, and the same activity with different strategy parameters.
I
Increase the flexibility and efficiency of sequential axial operations by simplifying the selection of bottom and top, and adding circular motion. The axial plane of a sequential axial activity references the stock top plane, stock bottom plane, hole top plane, hole bottom plane, and other axial planes. Define a sequential axial activity in a more generic way.  Define a chain of planes with the ability to use another axial plane as a reference.
