[SOLIDWORKS] SOLIDWORKS Design Professional
User Experience Value
SOLIDWORKS AI - LEO helps engineers move faster from design through manufacturing by turning complex engineering tasks into intelligent, guided workflows. Improved Assembly Performance Analysis provides more specific, trustworthy recommendations for diagnosing slow assemblies. Drawing automation now supports hole tables, multi-sheet layouts, and bulk drawing creation, helping teams produce consistent documentation with less manual effort. Natural-language macro generation makes custom VBA automation accessible without requiring extensive programming expertise. Design Analytics helps answer critical design questions while identifying missing information, such as unassigned materials. Manufacturing intelligence brings decisions upstream: Design for Manufacturing Guidance identifies 3-axis CNC issues and recommends corrective actions; Manufacturing Model Generation automatically creates mean-tolerance models from CAD and PMI; and Tolerance Stack-up Analysis identifies cr
I
Find relevant documents faster by keeping recent document lists focused on your current work.
I
See which System Options and Document Properties changed in this release without leaving the Options dialog.
I
Save your designs to the current release or a previous one, and set your preferred save version once.
I
Design with greater speed and confidence in real-world environments by importing massive, full-color point clouds that make it easier to distinguish objects and understand surrounding conditions.
I
Maintain consistent fillet width with the Chord Width option for edge fillets.
I
Model sheet metal parts accurately by creating stamped features directly across bends, simplifying design and eliminating time-consuming workarounds.
I
Fully constrain a component with fewer mates.
I
Define welds faster and with less manual effort by automatically identifying intersecting geometry and applying weld beads across multibody parts.
I
Exclude selected views from rebuilds so large drawings update faster when working.
I
Lock a sheet format so no one changes it by accident.
I
Communicate surface texture and geometric tolerance requirements more clearly with standards-compliant areal zone symbols, helping ensure design intent is accurately understood downstream.
I
Document company and project-specific tolerance requirements more easily with customizable profile tolerance tables, improving flexibility and consistency in manufacturing documentation.
I
Open a model from an assembly or drawing view and see it in the same display state you were looking at.
I
Know right away when a collaborator modifies a document you have open, so you don’t overwrite their work or build on an outdated version.
I
Align SOLIDWORKS Design with 3DEXPERIENCE data concepts, making physical product and representation workflows clearer and easier to manage.
I
See that your PartSupply search is running while Find Similar retrieves your results, so you know the system is working and don’t wonder whether to search again.
I
Use LEO and other AI capabilities without storing or managing your data on the 3DEXPERIENCE platform.
I
Publish parameters only when your simulation workflow needs them, so your saved data carries only what you use.
I
Render smoke, fire, and clouds that show light passing through and scattering within them, instead of reflecting off a surface.
I
Ask LEO for a drawing and see a preview right away. Avoid long lists of settings and get to the result faster.
I
Know your part can be milled before it reaches the shop. LEO checks designs for 3-, 4-, and 5-axis CNC milling and flags sharp internal corners, thin walls, undercuts, large shallow bores, angled surfaces, and more. For every warning or failure, LEO explains why the check was triggered and recommends a specific fix, so you can resolve issues in the model and avoid costly rework later.
I
Generate a model that hits the middle of your tolerance band, with no need for manual re-modeling. LEO reads the tolerances and datums in your CAD and PMI, recalculates each asymmetric dimension to its mean value, and creates an unlinked mean-model configuration for you.
I
Generate and save assembly structures in a single step with the ability to import and export CSV files and make easy template changes, while preventing unintended large-scale structure edits. These enhancements create a faster, more reliable, and user-friendly workflow by enabling easy template changes, preventing unintended large-scale structure edits, supporting CSV import/export for review and reuse, and allowing users to generate and save structures in a single step.
I
Answer design review questions without checking each component manually. Ask LEO about mass, density, and materials, and identify missing material assignments that could affect the results.
I
Save time on repetitive work and reuse the same process across designs. Describe the task to LEO to create a macro without writing code yourself.
