Ensure smooth transition to 3DEXPERIENCE Platform by accessing your SOLIDWORKS PDM from 3DEXPERIENCE SOLIDWORKS. Enforce company rules with multi-approval stamps on drawings.
User Experience Value
Connect & collaborate easily with industry peers by accessing 3DSwym directly from inside SOLIDWORKS. Improved large assembly performance during Iterative Design process.
Detect intersections between solids and surfaces, as well as between just surfaces
Initiate the ECAD-MCAD design process directly in SOLIDWORKS with the ability to define a New PCB Assembly and pull design changes, such as board outline modifications, directly into SOLIDWORKS
Enables improved control of flattening 3D harnesses comprised of either single segments or discrete wires
Improve quality and speeds creation and design changes for electrical harnesses designed using SOLIDWORKS
Speed harness design and documentation by better handling electrical splices in the flattening process
Speed precise design of pipe, tube, and other route types by enabling selection of the route origin up front which eliminates the need for time consuming adjustments later
Conveniently view and assign a 3D model (e.g. a casting) or raw material to the physical product that will be made directly from with MySession panel
