[SIMULIA] Structural Mechanics Engineer
New options for contact (e.g. interference fit with Explicit, surface properties)
Support the generation of Substructures, collections of elements from which the internal degrees of freedom have been eliminated, useful in some cases for computational and organizational reasons
Support of the direct-solution steady-state dynamic analysis to allow such analysis when the modal superimposition cannot be used
Data Management of SOLIDWORKS Simulation results files in the 3DEXPERIENCE platform for IP capture and traceability
New Parametric Design Study app providing parametric-based design improvement tools for native design models
User Experience Value
Geometry (point, axis, plane) creation allowed directly from meshing, abstraction or connections dialog boxes
Copy of existing mesh groups when using mesh transformation operators
New option to restrict the number highlighted points on a contour plot with the Show Min/Max Values functionality at user convenience
"SOLIDWORKS - Data Management of SOLIDWORKS Simulation results files in the 3DEXPERIENCE platform for IP capture and traceability"
Meshing - Copy of existing mesh groups when using mesh transformation operators (e.g. translation, symmetry) to improve the pre-processing experience
Scenario - Support the generation of Substructures, collections of elements from which the internal degrees of freedom have been eliminated, useful in some cases for computational and organizational reasons
Post-Processing - New option to restrict the number highlighted points on a contour plot with the Show Min/Max Values functionality at user convenience
