Reduce the turnaround time for multiphase simulations via ability to run the multiphase solver at a time step different from the global time step
Reduce or eliminate user task time spent in achieving simulation convergence via improved default settings for solver numerics
Quickly get feedback on meshing settings used and resolution of the model captured for medium sized (< 50M elements) models by meshing using local resources via reduced memory consumption for hex-dominant meshing
User Experience Value
Democratize the use of electronics cooling component models to designers/product engineers for mainstream applications via simplified setup for compact heat sink component models
Run and monitor multiple simulations concurrently by permitting simulation monitoring when running jobs in non-interactive execution mode
Improved results visualization when dealing with non-uniform mesh distributions via mesh-independent visualization for symbol plots
