Potion Lab
Iterator Action in Potion Operator
You can use an iterator operator to loop on a multi-value variable and execute actions for each item of the variable.
Benefits: You are able to execute in loop on multi-value variables.
The action called "Iterator" executes a loop on a multi-value variable within a maximum of 50 times, or for the number of times that you specify.
For example, you might want to loop on the list of deliverables associated with a task. You can create an iterator on the Deliverables variable and select the actions that you want to loop inside the iterator, such as "Add content to a bookmark." You can then select the variable "Iterator current item" variable in the Content field that represents a single deliverable for the respective iteration.
Asset Enhancements
There are several improvements made for triggers and actions.
Benefits: These enhancements provide additional actions and triggers.
List of enhancements:
  • Bookmark Editor triggers: Bookmark created, Bookmark Content added, and Bookmark Content removed.
  • Project Planning action: Create Project from Template.
  • 3DDrive action: Get folder details. It also has the Supported 3DDrive Folder out variable for the triggers File created and File updated.
  • 3DSwym has the Supported author out variable for Idea, Post, Question, Wiki, and Media in a trigger or an action.
  • For triggers, you can filter the events using community tags.
  • For actions, it is possible to create content in a user's Personal Space.
  • New action to create a post with files(s).
Duplicating Potions
You now duplicate a potion.
Benefits: You can create a potion with ingredients from another potion.
The duplicated potion retains all the trigger and actions data, including the input values. You can edit the duplicated potion and rename it.
