Potion Lab
Industry Business Analyst Ingredient
There is a new trigger There is a new digest in my Channel in the Industry Business Analyst ingredient that allows actions to use the digest content as a rich text variable, for instance to create a 3DSwym post..
Project Planning Ingredient
  1. Thanks to the two new triggers for 'When', Gate Description Changed and Gate Date Changed, have been introduced in Project Planning you can trigger potion executions when the gate description or the gate date is changed.
  2. Create Standalone Task action in the Project Planning ingredient has been updated to include the following new input parameters:
  • Planned Start
  • Planned End
  • Duration
As a result you can now specify the duration, start date, and end date at Standalone Task creation.
3DSwym Ingredient
You can now select Conversation as an input parameter, in addition to Personal space and Community when creating a post.
You can include a Conversation under Create a Post as target in addition to Community and Personal space. Conversation is a dynamic field that populates with list of user's favorite conversations.
Business Process Play as Ingredient
Business Process Play app has been added as an Action ingredient ("Then" side) for Potion Lab allowing you for instance to start a business process when a document has been created with a specific title.
Derived Format Management as Ingredient
Derived Format Management app has been added as an Action ingredient ("Then" side) for Potion Lab allowing you for instance to get derived output conversion status at a regular time interval using Potion Scheduler.
Comments 2
MB
MB 2026-03-09
@AB What does exactly count the Potion Lab? Only STEP, PDF, ...? are UDL generation also counted?
MB
MB 2026-03-11
and could you please describe how it works with tokens?
