Potion Lab
Project Planning Ingredient: Generate Project Report
AURA-Generate Project Report action is now available for Project Planning ingredient.
This allows you to use Aura to generate a project status report containing task details for a selected project. You can then use 3DNotification ingredient to share the report by mail.
Automatic Potion Deactivation after Failures
In order to avoid endless failure loops on scheduled or event-driven potions, failed potions are deactivated after 5 consecutive failures. When it happens, you will get notified of the deactivation. In any case, to find out if your potion was deactivated you can check the execution log and potion status.
3DSwym Ingredient: Manage Community Members
In 3DSwym ingredient you can now automate adding, updating, and removing 3DSwym community members thanks to the following actions:
  • Add members to a community
  • Update a community member role
  • Remove a member from a community
Industry Business Analyst Ingredient: New Role Prerequisites
The There is a new article in my Channel trigger and the Pushmail action now require you to have the Social Business Analyst (NBA) or the Social Business Explorer (NBX) role.
Note: If you do not have either of these roles, the potions that you created with the There is a new article in my Channel trigger or Pushmail action before R2027x GA will no longer work.
