[GEOVIA] Surface Mine Designer
1. Improved safety and accuracy of the Mine Design process offered to the user, connected to the ability to apply a range of Parameters to each Geotechnical Zone
2. Create practical and efficient pit designs through the ability to remove small bench contours and small toe contour expansions when it is required.
3. Improved interoperability with downstream planning process through the ability to generate key inputs to the Tactical Mine Planning Role
4. Improve practicality and safety of Ramp Designs by allowing the application of vertical transition grades on ramp entry and exit points.
I
I
Expand bench parameters definition to cover pit and geotechnical zones
I
The ability to remove small areas and contours in the pit design
I
The ability to remove small expansions in the pit design
I
The ability to create centerlines and outlines in the ramp design
