[ENOVIA] Collaborative Designer for Altium Designer
mport of DBLib from Altium Designer into 3DEXPERIENCE will greatly improve time to production and support companies using DBLib's for legacy library management.
Early visibility of manufacturing output improves accuracy for manufacture of PCB's
New Library and Bookmark selection brings a consistent user experience between Web and Win within Altium providing less training to the end users
Assignment of company standard 3D models to electronic parts is easily done through the Electronic Component Editor adding more flexibility to component creation
When a Bare Board is created for ECAD, a default templet will be assigned making it easier for the board designer to get started in their respected ECAD application
User Experience Value
Enhanced Work Under visibility assures users changes are be tracked and recorded in the Change Action
Remove the set context menu during login if enabled, making the login process shorter
I
Import DBLib to support customer database libraries Greater visibility for Work Under Widget UI support for Classification and Bookmark
I
Import DBLib to 3DEXPERIENCE provides fast load of legacy components
I
Generate and preview manufacturing outputs before saving to 3DEXPERIENCE
I
Consistent UI between Web and Win when using Classification or Bookmarks
Comments 1
JL
JL 2023-02-13
I am not getting the option to load dblib files.  Is there something I need to enable?
