- The system will use rules to manage identical parts and take into account changes on the master part. This eliminates the need to manually update each part when a master part is changed, saving time and reducing errors.
- Export data in both profile XML and plate XML formats simultaneously, rather than processing them separately. This speeds up the export process.
- Batch Utility is enhanced to generate manufacturing models through parallel processing. This removes the requirement for an interactive command launch.
- The logic for transferring margin feature compensation in flattened models is improved, leading to increased productivity.
- A new tolerance setting treats slightly bent profiles and plates as "flat". This eliminates unnecessary calculations at the machining level.
- Part planning functionality is now integrated directly into the Sync Manager, removing the need for a separate command and simplifying the user experience.
