[DELMIA] Recipe Management Engineer
- Initialization of DELMIA Formula and Recipe structure from BIOVIA Formulated Products: Avoid duplication of recipes in different 3DEXPERIENCE platform applications without traceability.
- Define criticality & Edge of failures at the Data Collect Plan Row and Resource Parameter Plan Row Level: Ensure uniform and accurate definition of Data Collect Plan and Resource Parameter Plan rows, representing recipe process parameters.
- Compare Recipes down to Process Parameters with matching criteria: Be able to use ENOVIA compare to identify similarities not only based on lifecycle concepts but also matching attributes from one structure to another.
- Support ‘as entered’ value for Data Collect Plan row, Resource Parameter Plan row: Manage keep format ('as entered' value with trailing zeros) for OOTB attributes set by the user at Data Collect Plan row or Resource Parameter Plan row level.
- Improve user adherence: Configure user specific views tha
User Experience Value
I
I
Definition of DCP / RPP rows using Criticality attribute and Failure Min/Max range
I
Compare recipes through custom matching criteria
I
Define and retrieve as entered values
I
NLS panel to review all the effective renaming
I
NLS definition panel to define new names for attributes
