[DELMIA] Recipe Management Engineer
- Achieve end-to-end continuity from Formula to Process Parameters, optimizing characteristics management by leveraging characteristics as inputs for data collection.
- Simplified and improved quantity management on discrete items by specifying:
* non-integer quantities to manage items splits
* integer quantities greater than 1 for items used in large quantities
- Deliver clear and more actionable guidance to reduce the likelihood of errors and improve user comprehension and compliance. By incorporating new types such as Warning, Caution, and Notes into textual instructions, authoring capabilities are significantly enriched.
User Experience Value
- Save time by simplifying data classification, enabling instant item classification at the point of creation.
- Improved process definition flexibility by managing work instructions items at any process level
I
New command to generate Data Collect Plan rows from associated items characteristics
I
Select a characteristic and automatically generate a corresponding data collect plan row
I
New capacity to define quantity on discrete items for multiple items of the same reference without requesting an instance for each (eg. no 3D and high quantity) or create or define a non integer quantity for items split (eg. 0.5 as half of part cut in two pieces)
I
Manage classification directly when creating an item, an operations or a resource.
I
Define instructions items at any level of the process structure. When defined at higher level, it usually applies at all below children operations.
