[DELMIA] Powder Bed Machine Specialist
1. Setup and program multi-laser powder bed machines to print parts faster and expand the scope of supported printers.
2. Reduce printing time and material consumption with a new minimal protective case based on the geometry and layout of the parts to print inside the case.
3. Improve the resulting part surface quality by creating volume supports with a fillet where the support meets the part surface.
User Experience Value
1. Reduce scan path calculation time by using multi-threading technology to leverage all available computing resources.
2. Increase user productivity by calculating complex supports in batch jobs while continuing to work on other interactive tasks.
I
Parts based envelop for protective case creation.
I
Add a new type of protective cases called Envelop-based which reduce the size of the protective to be as close as possible from the group of parts it is protecting.
I
Create a raft structure for Fusion Deposition Modeling (FDM) and Stereo lithography (SLA) supports.
I
Create volume support with fillet on top surface tangent to the part surface.
I
Support multi-laser machines
I
Multi-threading of scan path generation
I
Batch calculation of complex supports
