[DELMIA] Plant Layout Designer
Powered by AI - Streamline 3D scans usage by accelerating the data segmentation process to build the Resource BOM. Automatic identification of equipment based on an interactive 3D points selection, using a new dedicated command.
Accelerate the definition of Resource Parameters by reusing pre-defined standard parameter "templates" (eg. as pH, density, viscosity, etc.). These parameters can have some predefined values such as type, label, dimension and custom attributes.
Extended support to all kind of unit of measures (non standard ones supported OOTB by the Platform) by using "arbitrary" units, defined through administration tools.
I
Powered by IA: Object Interactive Segmentation from Point Cloud (Factory Scan)
I
Parameter Ontologies and Arbitrary Units for Resource Parameter Management
