[DELMIA] NC Milling Machine Programmer
- Automatically generate alternate toolpath strategies and parameters using AI, enabling NC programmers to significantly reduce machining time during roughing operations.
- Improve usability with a compare toolpath function to easily evaluate modifications between releases or when adjusting key parameters.
- Support shop floor operators with flexible, easy-to-customize NC documentation tailored to their needs.
- Simplify the selection of bottom and top surfaces while adding circular motion, increasing flexibility and efficiency in sequential axial operations.
User Experience Value
- Make cutting tool selection easier by enabling searches based on history or measured geometries, streamlining the process for users.
I
Support shop floor operator by delivering a NC Documentation that is flexible and easy to customize.
I
Increase usability with compare toolpath function to evaluate modifications between releases and while changing key parameters.
I
Simplify cutting tool selection by enabling search with history or by filling measured geometries.
I
Powered by AI - automatic generation of alternate toolpath strategies and parameters enables NC programmers to minimize the machining time in roughing operations
I
Increase programming flexibility with the introduction of surface creation by extending existing surfaces and avoid back and forth with CAD design.
I
Increase flexibility and efficiency of sequential axial operation simplifying selection of bottom and top and adding circular motion.
