[CATIA] Consumer Products Composites Designer
1. Top Surface from Virtual Stacking enhancements (Extended Limits, Local Areas Creation, Zero Thickness Areas)
2. Sub-stagger definition is kept when a sub-stagger is split
Integration of Junction Lines wizard in the Top Surface from Iso Thickness Area Command
What's New in R2023x for Composites video
New options to generate Top Surface from Virtual Stackings:
- Limiting contours
- Extended limits
- Surface with zero-thickness areas
- Offset with extension from curve
Integration of the Junction lines wizard in the Solid from Iso-thickness Areas command
Ramp definition, drop off definition and local overrides of existing sub-stagger of reference element will be retained after split
