[CATIA] Civil Designer
-Dual view alignment co-pilot displays measured distance to terrain and geological layer in addition to position
-Display real-world lighting conditions by casting shadows according to date and time with a heliodon
-Manage model contents by declaring initial features as 'construction geometry' that should not be built
-Cross-section design using a catalog of previously created cross-section components
I
New functionality for alignment design improves ergonomics and improves productivity in both the horizontal and vertical alignment command.
I
Improvements to rebar design increase productivity when working with groups of rebar layers
I
The dual alignment view now includes a horizontal strip to help understand the different conditions of the horizontal alignment, visible in the vertical alignment
I
An origin of the stationing can now be created, this prevents the existing stations from being modified when extending/modifying an alignment from the beginning.
I
The information panel for an alignment has be completely redesigned and is now customizable
I
Typical cross sections can be created and stored in libraries for easy access. These cross sections can then be instantiated into project cross sections and used in different models
