Hyperlink on Objects
- You can now access the new “URL Link” option the context menu of the following objects in the 3DWhiteboard app:
- Media: Images, GIFs, and videos
- Text boxes
- Sticky notes
- This allows you to add a hyperlink that redirects the user to specific internal or external resources for more information.
Layering Elements Automatically
- You can now use the auto-layering functionality to seamlessly arrange the images of different sizes on the canvas.
- As such, when you overlap images on the canvas, the smaller image is positioned automatically on top of other images.
Modifying Text Styles
- You can now modify the properties of your text by updating the following attributes of it:
- Font Name
- Font Style: Bold, Italic
- Paragraph Layout (Text Alignment)
Manipulating Elements
- After adding media on your 3DWhiteboard, you can now use the new 5-point handle to resize and seamlessly position your media.
- This handle can be used to rotate, resize, reposition, realign your assets.
Adding Unified Annotations and Sticky Notes
- The Annotations and Sticky Notes on your canvas now come with a default size, facilitating the creation of organized and consistently engaging content.
- After insertion, you have the flexibility to resize these elements as required.
Moving Layered Elements Together
- You can now use the new “Selection Mode” icon to move multiple assets in single manipulation..
- When you select this option, all the elements that are stacked together can be moved in a single manipulation.
New User Interface
- You can now use redesigned 3DWhiteboard app interface that a has consistent arrangement of tools and options for seamless ideation and brainstorming. The user interface for mobile devices is also revamped for smoother experience.
- Media Panel Container: Media types are visible on the left side of screen. Clicking a type will show the media panel.
- Undo Redo button: Positioned on the left side of panoply bar
- Panoply Bar:
- Panoply bar icons have been updated, with active buttons now highlighted in blue.
- Clicking an active button in the panoply bar deactivates it and ends its associated panoply or command.
- The panoply bar includes buttons for: Sketch, Highlighter, Eraser, Diagram, Text, Sticky Note, Reframe, and a three-dot button for additional menu options.
0
