[3DEXPERIENCE Platform] Collaborative Business Innovator + Collaborative Industry Innovator
New simplified Tagger Experience
  • Offers an efficient way to display the Information, understandable by all Users in one shot.
  • Offers a Tagger that is more Social : Swym Types are put at the 1st level.
  • User are less polluted by non pertinent content retrieved thanks to Type categories.
Layout improved
To increase Tag usability and improve productivity, the Signature 6W are always available.
Dedicated experience for each "W"
  • Select location (Geographical or Logical) using Where
  • Understand Object types using What
  • Select Dates using When (in 3DSearch)
  • Identify People using Who
3DDASHBOARD
Dashboard thumbnail
You now have the capability to add a thumbnail to a Dashboard you own. This thumbnail will be visible on the left side menu and manage dashboard view.
To configure the dashboard thumbnail.
Dashboard with thumbnail visible in Manage Dashboards list
Dashboard with thumbnail in Dashboard side menu
Note: When there are more than one owner on a dashboard, only one thumbnail can be set. When any of the owners replaces the dashboard thumbnail, the modification is for every members of the dashboard.
Add notification email configuration
From the 3DNotification Center settings panel you can now enable (by default) or disable email notification for 3DDashboard.
Manage Dashboards enhancements
In the continuity of the new manage dashboard that has been delivered on R2021x FD1, here are the new capabilities:
  • Now in Manage Dashboards, there is a dedicated search box to search dashboards in All Dashboards, My Favorites and Recycle bin view. There is also a new action bar with options like Sort, Filter, Multi-selection, Select /Unselect all to better assist you with your dashboard management. Other actions like Add as favorite, Remove from favorites, Delete and Restore, will be available depending on the selected view (All Dashboards, My Favorites or Recycle bin) and with a selection on one or more dashboards.
There are different ways to order the dashboard list depending on the view:
  • With All Dashboard and My Favorites, you can sort dashboards based on Modification date and Title of the dashboards.
  • With Recycle Bin, along with Modification Date and Title, there is an additional sorting condition for Deletion date.
  • There is a way to filter your list based on the role you have with the dashboards (Reader, Contributor or Owner)
WeDo
You can now create WeDo when using your mobile device. WeDo are now indexed, so you can find them in search results and easily filter on them in 6WTagger.
Wiki: concurrent authoring alert
When you are authoring a wiki page at the same time as the other authors of your community, you will be alerted that someone is also working on the same wiki page.
Here are the cases:
  • Some user has modified the wiki and your 3DSwym page is not refreshed.
    Then on editing the wiki, you will get the popup for page refresh and your page will be refreshed automatically.
  • Multiple users have started the Wiki edit simultaneously.
    On Publish by any of the user, all the other users will receive a warning that the wiki has been updated and will suggest you to save the edited wiki data in some other application.
3DSwym Conversation Lifecycle: Support Persistent Policy
  • Now you can configure the Conversation Automatic Removal setting. To do so go the the settings of your conversation, and select the desired behavior. You can either select Automatic removal enabled (default behavior prior to this upgrade), or Automatic removal disabled to indefinitely keep the conversation.
  • On changing this removal behavior, all the members of the conversation will be informed of this change directly in the conversation.
  • In 6WTags, you will get a new tag to filter messages of this persistency change
Publish to 3DSWYM: form refactoring
This concerns the removal of long listings (communities & ideas) when creating a post from What's New or transferring anything to Ideas. The container for selecting community used to load all the communities at once. Now this container is loading 50 communities at a time to improve performance.
When creating content is What's New
When transfering to idea
Sketch integration in 3DSwym
See below in 3DSketch section for more details.
3DSketch
  • Create and Edit 3DSketch through 3DSwym (in addition to My3DEXPERIENCE)
    • Create:
  • Edit:
  • 3DSketch in My3DEXPERIENCE Mobile App (IOS & Android)
  • Copilot and Sketch assistant enhancements
    • Perpendicular segments
  • Parallel segments
  • Join two aligned segments
  • Circle tangent to the axes of the plane
  • Align ellipses to the axes of the plane
  • Align concentric ellipses
  • Zoom independent smoothing
3DDrive
The upload has been improved as you can now upload an entire folder and its content from your computer while preserving the folder structure.
Once the upload has started, you have the ability to cancel all current and pending uploads or any of the uploads.
Notice also the new upload management style.
User Groups
Once a User Group is created, you can now edit its name and description in multiple languages.
Drag & Drop of users is now supported to fill the Members of a group or to share group modification privilege with others.
Create lean ad hoc route tasks for approvals with new mobile user experience.
Video
Ease collaboration between the stakeholders by adding additional information to documents as attachments and get notified of lifecycle changes.
Prevent users from working on items that are no longer valid by obsoleting items during the work-under process.
