[3DEXPERIENCE Platform] Collaborative Business Innovator + Collaborative Industry Innovator
New features about conversations
  • All members of a conversation can now edit the contents (Posts, Media , WeDos), except messages of others.
  • When trying to Forward a content from a conversation to anyone with whom we don't already have a conversation, we can select this person and a conversation with this person will be created and the content forwarded.
  • Now you can start a new conversation reusing the same members of an existing conversation. Don't forget to set a topic to differentiate the two conversations.
Capabilities to filter on content Liked or Commented
You need to find a content and the thing you remember about it is that you Liked or Commented it. It is now possible to find this content by using the Commented or Liked tags available in 6WTags panel under the Preference (What) predicate.
Forward 3DStory
Since R2021x FD04 release, you can now easily republish content using the Forward functionality. While it was not possible on FD04, with FD05 you can now also Forward 3DStory content.
    SVG Vector Images are now supported
    You can now use svg images to display high-resolution diagrams without losing details and accuracy. This type of file can be searched, indexed, scripted, and compressed.
    Miscellaneous change
    The List my communities command, formerly available in the left pane, as been replaced by a Show All command.
    3DDashboard
    • If you are playing a Story while a widget on this dashboard is maximized, you are now notified to restore the original size of the widget to continue playing the story. Here is how.
    • When at least two dashboard owners are working on the same dashboard, they will be notified in case of concurrent and conflictual modifications, like for example, tab creation, tab position, widget layout or size. Let's see how this works.
    • When creating a new folder you now have the possibility to provide a description to explain what it will store. As this description is indexed, it can help you find your folder through a search query.
    If you'd like to add a description to your existing folders, you will need to Edit them.
    When a description is provided for a folder it is visible here:
    3DSearch and 6WTags
    Tag creation common User Experience
    As you can already experience it with in-line tagging in 3DSwym, a common experience is now available in the 6WTags panel. You no longer need to specify one of the 6W, they are all suggested to you and you can select the appropriate one.
    3DSearch - Queries robustness
    Search performances becomes endangered when the number of objects retrieved is too high, especially on the cloud. System protection have been implemented to limit the number of objects searched and a dedicated user feedback is displayed when such limit is reached.
    3DSketch
    Now about what's new with 3DSketch in this release:
    • 3DSketch now supports a larger scope of image types, including handling image transparency
    • Various User Experience enhancements:
      • "Sketch it" scenario is fixed
      • Erase command visual feedback improvements
      • Automatic line intersection detection performance improvements
      3DStory
      Let's discover what is new with 3DStory:
      • Interactive Onboarding: New users will now be guided through the application's main features by an interactive guided tour, available on the Welcome Screen.
      • 3D Model Viewer improvements: Users can now add nice visual effects and simple animations to their 3D Models.
      • Forward story to other community: Users can now forward their story to another community using the 3DSwym Forward command also available on media and posts.
      User Groups
      As you know, in the User Groups widget you have two views:
      • My Groups view to display all the groups you are the main owner,
      • All Groups view to display all the groups available on the platform.
      Within the All Groups view you now have the capability to filter on the groups you are Owner (not main owner), Manager or Member.
      1. Manage efficiently documents with seamless creation, edition and lifecycle management in Document Management app.
      2- Improve review thanks to extended support for annotation of document (DWG, DXF formats) in 3D Markup app.
      3. Better control of integration of design alternative thanks enhanced merge capability in Collaborative Lifecycle app.
      4. Reduce time for document access thanks to inclusive actions for documents in Issue Management app.
      5. Reduce time for comparison thanks to easy access to related objects such as documents and requirements in addition to structure objects in Compare app.
      6. Collaborate with peers thanks to collaborative comments in 3DPlay app.
      R2021x FD05 What's New Collaborative Industry Innovator main enhancements.
