[3DEXCITE] Marketing Experience Creator
1. Optimize web experiences for interactivity during publication in Play Optimization with the "Optimize frame rate over memory use" option.
2. Optimize textures when publishing glTF models through Play Optimization, with several options of KTX2 texture compression, from best quality to small file size.
3. Easily import published paths from curves linked to a product asset into interactive experiences.
User Experience Value
There are several user experience improvements like:
1. Avoid time-consuming path creations by reusing existing curves from the product assets inside the interactive experience.
2. Faster loading times and better performance of glTF models on mobile devices thanks to compressed and optimized KTX2 file size exports.
3. Several workflow improvements during experience creation: Copy-n-paste properties of 3DActors; reset property values; filter directly from the project panel and benefit from an improved search command.
Save time by importing paths from engineering
Improved search for experience content
Reduce size of published glTF models with KTX2 texture compression
