Widget PWA
You can now install a dedicated (and instantiated) widget inside your mobile device using new feature "Send to device"
From desktop, a QR code will be generated and allow you to scan the widget with your mobile device.
With your mobile device, scan and follow instructions to install on your Android or iOS devices.
Add a confirmation dialog on delete tab
New confirmation modal has been introduced on delete tab:
Be careful, you can't remove all tabs, in case of latest tab another modal will prevent you to delete the last tab of the dashboard
Webnote fixed toolbar as option
On WebNote you can specify that toolbar must be fixed on top and always visible (even on scrolling)
By default is unchecked but you can change via Widget preference
As soon enabled your toolbar will be sticked to top and never hide
0
