xApps (xDesign, xShape etc.)
You can view the System Status of the app running in the browser tab widget. Benefits: If experiencing problems in the app, you can view the System Status to see what might be causing the issue. The System Status provides information on the network and server connections, as well as browser and server memory resources. For more information, see Checking the System Status.
Selective Save helps you manage unsavable sessions by allowing you to save only the savable changes you have made in an active session. Benefits: Earlier, you could not save your changes when the Save failed in an active session. But, now you can retain all your savable changes. For more information, see Saving Components.
You can now hide components using the new Hide Components option in the Measure dialog box. You can also adjust the translucency of hidden components using Translucency Manager in the work area when the Measure command is active. Benefits: You can temporarily hide components to exclude them from the work area when you measure entities. For more information, see Measure.
The Linear Sketch Pattern and Circular Sketch Pattern commands now provide the option to skip the creation of a specific instance in a pattern. Benefits: This enhancement provides the flexibility to remove one or more instances of a patterned entity. When you enable the Skip instances option, white dots appear on each instance. Click a dot to skip a particular instance in the pattern. For more information, see Creating Linear Sketch Patterns and Creating Circular Sketch Patterns.
You can display the product cut by a specified volume, showing the internal space. Benefits: You can specify a 3D space inside your product by customizing a volume area and the origin of that volume area to view. The geometry outside that volume area disappears from the view. For more information, see Creating a Volumetric Section View.
You can now insert your HomeByMe project into your model design. Benefits: When designing items intended for a particular space, such as the room of a house, having the larger context of your HomeByMe project to work within provides several benefits:
For more information, see Design in the Context of Your HomeByMe Project.
You can now create sketches on an imported HomeByMe reference geometry. You can also: Assign dimensions and constraints to the sketches created from the HomeByMe geometry. Select faces in the imported HomeByMe model to use them as references to create or edit sketch planes. Benefits: Using the HomeByMe reference model, you can draw sketch entities and model them. For more information, see Design in the Context of Your HomeByMe Project.
When you finish adding designing features to the imported HomeByMe geometry, you can publish your model back to the HomeByMe app. During publish, a redundant HomeByMe data is now excluded from the export and specific components can be selected. Benefits: You can avoid publishing repetitive data. For more information, see Sharing 3D Files with 3DSwym Communities. |
xDesign
You can now add xDesign features in an imported HomeByMe model by using HomeByMe reference entities such as planar surfaces and vertices. The reference features that you use to create designing features are known as isolated features. Note the supporting features:
Benefits: You can add more features to your HomeByMe model. For more information, see Design in the Context of Your HomeByMe Project. |
xDrawings
You can create a section view, which displays the product cut by a plane, showing the internal structure. Benefits: 3D section views illustrate internal structures clearly. For more information, see Creating a Section View. |
xFrame
Note the following enhancements in the structural Linear Pattern and Circular Pattern features. You can:
Benefits: You can create patterns more efficiently. For more information, see Structure Patterns.
During plates creation, you can now select multiple members to add plates to them. You can also:
Benefits: This enhancement helps you save time and improve efficiency. Previously, you could select only one member at a time to add plates to. For more information, see Plates, Gussets, and End Caps. |
xShape
You can now bend features without selecting a plane first, and use a horizontal handle instead of a vertical one. It is also possible to bend only the selected features, and not the surrounding ones. Benefits: It is possible to bend specific features of the model in a more efficient way. For more information, see Creating an Arc Bend.
You can now flex features using an improved handle (not overlapping with the Robot handle, and that remains normal to the view). Benefits: It is easier to flex features in the 3D area. For more information, see Translate or Scale Subdivision Objects.
If you crease one or more edges of a subdivision object, the edges remain selected in the 3D area following the manipulation. Benefits: It is possible to work more efficiently on a specific set of entities by not having to select them again between two manipulations. For more information, see Creasing Edges on a Subdivision Face. |
xSheetMetal
The Wall from Edge mini panel is updated and now you can create a wall from an edge from a sketch from the mini-panel. You can switch between creating a wall from an edge and from a sketch. Benefits: You can create a wall from edge from a sketch from the mini-panel. For more information, see Creating a Wall from an Edge. |
SOLIDWORKS Connected and Design with SOLIDWORKS
When you right-click a file in MySession and select the Save with Options command, you can click and expand Lock at the bottom right of the Save to 3DEXPERIENCE dialog box to Lock All objects or Lock Selected objects in a part or assembly. It is also easier to find the Lock control. It has moved next to the Save control at the bottom of the dialog box. Benefits: You can lock selected files in a part or assembly. For more information, see Save Dialog Box.
In the Save to 3DEXPERIENCE dialog box, you can add a Revision Comment for individual objects when you click the Save or New Revision checkbox. To enter a comment, click your cursor in the cell that appears in the corresponding row under the Revision Comment column. You can also edit the revision comment from the properties page of the object. In earlier releases, you could only add revision comments for an entire part or assembly. Benefits: You can easily add and find comments related to revisions for individual objects.
You can open 3DDrive, drag files from 3DDrive or upload files to 3DDrive directly from the Task Pane. Before you can use 3DDrive in the Task Pane, you must install the 3DEXPERIENCE Drive Sync Client. Benefits: You can access 3DDrive more easily.
You can use the Add to Bookmark and Open Bookmark Editor commands to quickly open the Bookmark app and add files to Bookmarks. Access these commands from the Lifecycle and Collaboration toolbar, CommandManager tab, or shortcut menu. You can also customize keyboard shortcuts, mouse gestures, and the S-key for these commands. Benefits: You have more flexible ways to add files to your Bookmarks app. |
When you connect to the 3DEXPERIENCE platform, a progress bar at the top of the window informs you about the status of the connection. In the Recent Documents list, cloud icons indicate documents that are saved to the platform. The reorganized Save menu shows Save to This PC on top. Benefits: You can easily see the state of your connection to the 3DEXPERIENCE platform and know which documents are saved there.
In the Insert Component Property Manager, you can specify the position of a component as Only fix first component, Fix, or Float. You can select Float when inserting the first component. Previously, the default behavior positioned the first component as fixed. You can use Only fix first component to position only the first component as fixed in the model. Benefits: You have more control over the component position when inserting components in to your model. For more information, see Insert Component/Begin Assembly Property Manager.
In the Advanced Component Selection dialog box, you can specify Flexible, Envelope, and Excluded from BOM for Component Status. From the Select flyout , you can use Select Flexible Subassembly to select flexible subassemblies in the model. Benefits: From a top-level assembly, you can select the highlighted flexible subassemblies in the Feature Manager design tree. You can easily find assembly envelopes, flexible components, and components that are excluded from the BOM. |
The Administrator can choose in which Collaborative Space and Maturity state, the toolbox and part supply components are created. It is also possible to delete these external components from the Collaborative Lifecycle app. The Administrator can define the values of Collaborative Space and Maturity state, in the Standard Libraries Management app. Benefits: You have flexibility to manage the external components imported on the 3DEXPERIENCE platform. For more information, see Configuring Standard Libraries Management. |
Social/ Web-Apps
3DSearch
Filter your content more efficiently with distinct icons for each filtering option (Relevancy, Most Recent, Oldest, Sort by title A>Z, Sort by title Z>A, Sort by Type)
This enhancement provides you with the ability to search Tags if values are not found in the search panel. You can use the search button from 6wTags panel to look for desired tags
Previously there was an option to activate it if needed, now it is active by default to enhance productivity. |
3DDashboard
You can now mark one Dashboard as a ‘Home’ Dashboard, so it will be displayed upon connecting to the platform by default |
Issue management
Easily find the issues of attention by filtering them according to specific “Affected Items, Resolved Items or Context” in Issue Management app Make informed decisions on documents attached to a route, thanks to the new Approval Status column in Document Management app. Improve collaboration on 3D, by defining and sharing a startup view, in 3D Navigate app. To discover more about these enhancements, please go to this link on the ENOVIA User's Community https://r1132100503382-eu1-3dswym.3dexperience.3ds.com/#community:38/wiki:cNEIE6VGRTulk0bKpkfyjg |
Project Planning
3DPlay
3DPlay widget adopts the home page to allow you to browse and load your content easily and access to useful links
Introduction of a topbar in 3DPlay widget to improve the user experience and keep it unified in all applications of the 3DEXPERIENCE platform. The topbar contains global functionality like Publish, Information, Share as Comment…
Share comments and annotation made on images- On top of collaborating and sharing comments on documents and 3D content, you can now also do so for images whatever the source: 3DDrive, 3DSwym or 3DSpace.
Access specific information quickly, by using search not only in document text, but also in text annotations.
The default visualization for 3D content changes to Material and No Edge in order to bring you the best rendering instantly.
3DStory
| https://r1132100503382-eu1-3dswym.3dexperience.3ds.com/#community:g_fzYGr0Q6mHYxoVvGKnOw/media:5j026jR2SUOTqsJjlYNudg |
CATIA
💥Lattice Designer- Exciting New Role!
A Lattice is a simple shape pattern replicated in different directions. A designer can fill certain regions of the design with a Lattice to improve the performance of the design. Lattice Designer Role is available with Engineering Exper role (U2D) Lattice Design app will enable the adoption of lattice structure in high performance parts, providing conceptual and detailed 3D Lattice modeling capacities seamlessly integrated with structural validation, and outputting 3D Printers and readable formats. The Lattice Design Assistant in the app guides you through the process of the lattice design. It helps you navigate through all different steps from defining the body to lattice, the cavities, launching lattice conceptual design, and validating the design. Please view DETAILED WEBINAR below for more information: |
Part Design
Functional Generative Design
Produce automatically lighter parts or assemblies, thanks to an enhanced Generate Shape command for topology optimization on solids adding less material around frozen areas |
Creative Design Experience
SIMULIA
Durability and Mechanics EngineerPredict durability of thin welded structures using the FKM-based methodology with shell representations |
Fluid Dynamics EngineerSave time to create steady-state and transient fluid simulations through the new analysis case initialization dialog |
DELMIA
Powder Bed Fabrication
Shop Floor Equipment Engineer
Now you can validate your manufacturing processes by doing a kinematic simulation of the machine, installing parts on the bed, define the working area, ergonomics, and how much area the tool will cover. Use the same machine in the plant layout to simulate the working of the company in order to make it efficient. Define and validate the mechanical behavior of shop floor equipment in a virtual 3D environment by designating and testing operational kinematic models of NC Machines, Robots, Conveyors, Tooling or any type of shop floor machine. The equipment models can then be re-used by downstream applications for plant layout, resource simulation and machine programming. |
💥 New Role
Manufacturing Process Engineer
Process Management (Web App)
