Wrap Feature-Part of the Feature Failed to Cut the Body
I am modelling a coronary stent.  I have a sketch of the flat pattern and an extruded hollow clyinder.  I want to wrap/emboss the sketch along the inside of the cylinder.  Whenever I use the wrap feature, I can see a preview of the wrap but then get the part of the feature failed to cut the body error.  Is there a way to fix this?  I've attached a copy of the file.  I've also attached a copy of another stent I have modelled so that you have an idea about what I am doing.
SolidworksParts And Features
Answers 4
SM
SM 2011-06-17 Best Answer
Hi Jared,
Welcome to the forum.
I have not opened your part, but one question comes to mind.
Is the entire wrap feature encompassed within the body walls?
If not, it needs to be or it will fail.
SF
SF 2011-06-17
I'm not sure why the wrap didn't work, the equations seem correct and the numbers add up. I did manage to complete the wrap by extending boss-extrude 1 (direction 2) and by adding .0001mm to equation 2. This method created a gap at the end of the wrap feature but can fixed with a little fill. I haven't tried this but an alternative method would be to wrap a small section of the sketch and then create a circular pattern of the wrap body to achieve the final result. Hope this helps,
SF
SF 2011-06-17
I will give these a try.  I need the model to be as accurate as possible.  I will be importing the model into Abaqus after it is finished.
SF
SF 2011-06-18
I tried to use the circular pattern, but that didn't work either.  I can use the option to add to the circular extrude.  I can either use surfacing to fill the gap or define a contact boundary condition in Abaqus.  Thanks for the help.
