Workgroup drag and drop issue
Hello All--
I have been building a library of parts in workgroup pdm for a few weeks now.  Today I went to make an assembly and tried to drag and drop parts from my workgroup client.  I kept getting an error that said the drag and drop was failing.  Has anyone had any luck draging in parts from workgroup or do you have to save a local copy and then assemble an assembly from a local copy?
SolidworksWorkgroup Pdm
Answers 4
JH
JH 2012-06-18 Best Answer
Dragging a part from the Workgroup vault into an assy works ok for me (SW2012 SP 3.0)
KV
KV 2012-06-18
Chris,
I'd like to see a screenshot of the error and know whether the library is setup as a Standard Library in pdmwg.
Best Regards,
Keith
SF
SF 2012-06-25
Grabbing a model from the Workgroup PDM vault using [Ctrl+LMB] to Drag and Drop should work using either SolidWorks Explorer or the Task Pane File Explorer.
My apologies if this comes across as sounding elementary but oftentimes simply rebooting the PC can alleviate those strange errors we all encounter from time to time.  If you haven't done so yet, it might be worth a try before expending a lot of additional troubleshooting effort.
Best Regards
WS
WS 2012-07-02
I have experienced this same problem in the past.  My solution was to shut down Solidworks and then start it back up.  I know its a hassle but it worked for me.  Now we have run up on this issue again with another user and this occurs just about every time a part is being placed in an assembly.  This is dragging from a folder in PDM rather than the "toolbox".  The shutting down method works but seems to be temporary because it always comes back.  Hopefuly a better solution is found.
