I've tried the search function but haven't found the right key words to locate what I want, sorry.
I'm trying to model a basic ring lug wire terminal for use in an assembly with Solidworks. This is a purchased part so I don't need it to build component parts from, but I would like it to be somewhat accurate for clearance checks. What I really want is to learn the basic steps to generate this on my own, but if I can find an existing example then I can learn from that and model up other sizes as well for our internal use.
My two biggest hassles are with the sheet metal tools and getting the wire hole to wrap around from a flat pattern, and then to get a semi-realistic blending bend from the flat ring portion into the wire/crimp tube. I do not need to show this in the crimped stage, uncrimped is fine. I will also need to model one up with the ring bent 90deg to the wire.
Not sure if this link will work to show something similar to what I'm starting from:
(imagelinked from the www.standardelectricsupply.com website)
I'm thinking this should be fairly simple once I can figure out how to do it. Or maybe not.
In any case thanks in advance for any help.
Mike
SolidworksSheet Metal
Mike,
SW does not have the ability to form multi-axis bends. They can be drawn but not flattened. Why don't you create a part with two configurations?
I can get something close without the sheetmetal tool via brute force cut and extrude methods. Is there a way to model the part as shown in the linked image and not worry for now about the 90degree bent use?
Yes! I did suggest that earlier, use two configurations in your part file.
search 3D Content Central for ring terminals. I can't vouch for the dimensional accuracy, but there are a bunch there.
Thanks, I'm currently waiting on the 3D Content Central access approval email. Thought I had signed up for that in the past but I guess not.
Mike, I use these all the time, gave up drawing my own! all of them don't have models, but most do. http://www.te.com/catalog/connectors/terminals-splices/menu/en/17698?BML=10576,17560, also, another great source for electrical conduit fittings is: http://www-public.tnb.com/ps/pubint/ads.cgi?promo=cadlibrary
I hope this helps!
I just went ahead and did a brute-force functional model with two configs.
I'll check out the links to those sites later, thanks.
Looks great to me!
Thanks. It would probably benefit me to hang out on this site/forum more.
I highly recommend it, there is ton's of information, even stuff you never even thought of!
The great part is, as configs you can swap them at will.
