Why won't 3D points show up when I open a step file?
I have a step file that I know contains multiple parts as well as points in a 3D sketch. When I open the step file in SolidWorks I can see the parts but the 3D sketch and points are not there. How can I get SolidWorks to recognize the 3D points? I know the 3D points are in the step file because a coworker can open them in AutoDesk Inventor.
SolidworksImport export
Answers 6
DP
DP 2017-02-23 Best Answer
http://www.engineering.com/tutorials/importing-a-step-file-solidworks/
If you don't click the link, copy paste below:
The best way to import a STEP file is through the “File” drop-down menu. Select “Open” and change the file type to look for STEP files.
Before we click “Open,” click the “Options” button to go over some of the options. The “Import Options” dialog box appears.
The defaults are usually safe to use, but it sometimes pays to take a quick look before importing a STEP file to make sure you get the results you’re looking for.
We can also choose to import point or curved entities to import the data as 2D and 3D sketch data, by selecting “Free point/curve entities.” This option is useful if you’re importing free points or free curves from either a CAD or analysis package. With this box checked, you can either have SOLIDWORKS import the data as sketches or as curve features. The user must decide which option will be best depending on how the data will be used.
SF
SF 2017-02-23
Dan,
Thank you for your help. I have the following import options and still I am unable to see the points:
comment imagecomment image
SF
SF 2017-02-23
Any other recommendations?
CC
CC 2017-02-24
How do you know the step file is legit?
Have you tried importing with the "import as 3D curves" button checked for grins?
SF
SF 2017-02-24
I know that the step file is legit because the points can be seen when imported in Autodesk Inventor and Unigraphics.
I have tried "import as 3D curves" with the same result, no points.
DP
DP 2017-02-24
Well, there are a couple of things to try:
I know that the kernel to import files into Solidworks leaves a lot to be desired.
That being said, can you export the file from Autodesk/inventor/unigraphics as a parasolid and then import it into Solidworks?
I rarely use Solidworks to import anything.   We have purchased a third party program called TransMagic.  It works great.
