I am simply trying to make a new assembly. A blank new assembly...When I do the assembly creates itself as a read only file. I cannot figure out how to turn this off.
I work off of a server regularly at my office. I am running SW 2015 on windows pro.
SolidworksAssemblies
I don't remember ever hearing of that before. I assume you're starting these assemblies with a custom template? If so, I'd suggest clicking on the Novice button at the bottom of the new document dialog box to get the default templates, and try that one to see if you get the same problem.
Yes I have tried that. I am simply using the default assembly template that solidworks loads with.
Then I don't know. Have you contacted your VAR to see if they can help?
, we see that here on occasion as well. The cause on our end is that someone saved a part/assembly out with the default name and had never renamed anything but then checked these files in to our vault. (IE:Part1.sldprt or Assem1.sldasm) Then when a new part is created and quickly saved (using the default names) it's read only because it already exists elsewhere.
John,
Even I am facing the same issue, only new assembly is opening as read-only. Other things like part and drawings are working fine.
Your answer make sense.. I checked in entire vault but I did not find any other assembly saved with the default name.
I am wondering if there is any other reason for that.
Any help or suggestions are greatly appreciated. Thanks !!
