I have a weird thing happening when adding a jog to a dimension line. First, I created a radius dimension, then used CTRL + LMB drag to add a second leader. I'm trying to jog the second leader line. When I RMB on the second leader line and select Add Jog Point, the jog point is added to the original leader line. What's worse is that the arrow head no longer lands on the geometry line. It moves to be on the imaginary diameter of that fillet. Even if I remove the jog point, I can't manipulate the arrow any more (IE: flip the direction of the arrow head). This happens regardless if I have addition arrow heads.
Does anyone know a) how to add the jog to the second line instead of the first line and b) what is causing the arrow head to move and how to fix that? I'd prefer not to have to create a note to accomplish this.
Solidworks 2017
BEFORE ADDING THE JOG
AFTER TRYING TO ADD THE JOG (NOTICE THE JOG POINT IS ON THE ORIGINAL DIM LINE, NOT THE ONE I TRIED TO ADD IT TO)
Interesting. The jog problem doesn't seem to be the problem, it is a symptom. Note that the new arrow created by dragging cannot be moved by dragging it again. However, if you drag the original arrow, the second arrow disappears and a new arrow appears. It's as though SW has lost track of which arrow head is in which location. I get all sorts of weird behavior with Jog, Insert Branch, arrowheads changing style. It's a mess. The problem is still there in SW 2019 SP3.
This has been a know issue for at least 10 years now:
And lastly, this has been an issue since at LEAST Solidworks 2009:
Interestingly enough, SPR 488070 does not come up at all in the search. Instead, it comes up with 488068.
Anyway....there you have it.
You could do what our company does; only dimension one radius, and denote the number of instances:
2X R0.031----------->
Thanks everyone for the replies. I never knew it was such an issue.
radius dimensions are very bugged, have been for years
I create notes all the time for radius dimensions.
radius dims wont go to "inside of arc" on drawing view with breaks.
can't go to "inside of arc" with jogged radius dims
can't go to"inside of arc" with multi leader radius dims
so i put the radius dim in, then add a note, link the note to the radius dim, then hide the radius dim. You can add leaders and jogs all day on notes.
edit: running 2017 sp5.0
Unless you have a specific reason not to, creating a Note might be your best option. You can link the note to the dimension, then hide the dimension and they'll remain linked, and it's much easier to control the leaders on notes.
Can confirm this is still an issue in SW2023 SP5 - it's really rather annoying.
Can confirm still an issue in SW2024
