In modeling a bowline knot by sweeping a spline, and choosing circular pattern to sweep on that spline, the end result looks good to the eye, but only until I zoom in on either one of the ends. Then do I find, not a circle but instead a circular-looking polygon of many segments. And the problem with this, is that I need one of those ends to mate concentrically in an assembly.
Know that the circular pattern is not from a sketch, but from the sweep option itself. So can't be to do with my circle not being an actual circle. Know also that I did make a point of "relaxing" the spline prior to sweep. Doing that once seems all that's allowed, since afterwards the option is greyed out.
So my question is, what causes the undesirable polygonization? How to avoid it? How to fix it if it occurs?
SolidworksParts And Features
Check the image quality for the file. The slider bar may be more to the left than you'd like.
Steve C
As indicated, that's just a graphics issue. It shouldn't affect the ability to apply concentric mates.
Thank you but I don't think it's that. If I zoom in on the assembly I'm trying to mate, there do I see a circle and a polygon. So the sweep really does polygonize itself. Any attempt to mate as concentric is rejected. I choose concentric and the extrusion will allow clicks, but not the spline sweep.
It's just a graphics issue.
Steve C
Yes, once you use sweep, it no longer recognizes it as a cylinder so you can't use concentricity.
The workaround is to create a point or a sketch line at the center to mate to. Which you should be able to create at the part level. If you have trouble with that let us know and some of us know a few tricks to get one fairly fast.
Well there then... It always helps to have a good idea of what others want and sometimes I/we overlook that...
Steve C
I know I said above you should be able to mate it, I wasn't thinking about it being created from a spline. Try attaching a short straight line at the end of the spline, and incorporating it into the Sweep.
More than simply a problem of mating ex-post-facto, trying to manipulate the spline knots in almost any way at all, causes the cross-sectional shape of the sweep to distort in a way that propagates outwards toward both ends, so that what you can end up with is nothing remotely circular ... an irregular hexagon, square, or even triangle!
That is something which never happens in Rhino.
In SolidWorks (at least in my case so far) any attempt to repair the situation by further manipulation just makes the end result worse. In Rhino, if the spline is too tight, the sweep might intersect itself, which is easily repaired by just moving the spline knots apart. An easy repair, as all I need do is choose the spline knot I want to stay put, then choose the others I need further away, and do a 3D scale, expanding the second away from the first. I find no such easy feature so far within SW. And in Rhino if a spline curve's too tight, the resulting sweep might kink ... but in a way exactly as you'd expect from bending a hose along a radius that's too tight. In SolidWorks I might also get that, but in addition, (and very irritatingly) I get this cross-sectional distortion, which propagates all the way to the free ends. That's behavior such as never happens in the real world. Which makes it very hard comprehending what is the cause. It must be following some setting or other. Where, please, can I find that setting and turn it off? Or some explanation for what is the cause, so that I can guess how best to correct it.
For now what I'm doing, is calling up Rhino, making my knots, exporting the spline via *.iges and then having SW sweep the imported curves. I'd like to learn the pure SW way instead. In another thread I asked for such examples as that. And I did get some, but all those were loose ... bowline knots all but ready to fall apart. Helpful so far, but no such loose spline exhibits this problem of inducing cross-sectional distortions that propagate all the way to the end. So I had marked that question answered.
If you will post your model here someone can probably help. It's difficult to do that from just a verbal description. Please see if you aren't familiar with the process.
- If Rhino works so good, why do the part in SW???? There are settings in the Sweep Feature Dialog box, another thing that makes a huge difference is the position of the round circle in relationship to the sweep path, the circle sketch plane must be direct and not skewed, if it's skewed then the cross section or end could show a weird shape....
Follow advice and upload your part..
Attached are two models in SolidWorks of what I'm attempting. This post, by the way, is not a rant on one product versus another. I have zero brand-name loyalty (Harley Davidson cured me of that long ago). This one thing alone, seems to work more smoothly and easily in Rhino for instances of sweeping on splines. SolidWorks has plenty of other features lacking in Rhino which I also covet. It's a SolidWorks class that I'm taking, so that in time I can take advantage of both. After then, maybe Creo? I'm a Test Engineer, so CAD is only about 5% of what I do. Still I want to be doing it well, as it is the only way to get test stands built in a timely fashion ... by dealing with the fabricators all by myself. The bowline knot is part of a project for my SolidWorks class ... the guy lines of an antenna structure for my ham radio hobby ... and which I will actually build. Once built, I'll publish it somewhere. So I want the files to be pretty, to look like real life. Being stubborn about each little hitch, unwilling to put it aside and move on, is perhaps a personality issue? But it's also a good way to learn. Please kindly check out my ZIP upload. There is also a ReadMe in there. In the end, I will publish all of my plans for free on-line.
Hello Gan,... I agree!!!!...
...and, sorry you went thru all this and hope you're not bald!?
..so, there is a little trick,.. if you see,.. this all goes south because the path runs near or into itself.. (yeah, I know.. who gives a rats... again, I agree!)
...here's the first part of the trick.. Undersize your profile so it clears by a good margin... that is, the Dia 0.1875 profile will now be "0.0875"... SHAZAM!!!
...now, the Rocky and Bullwinkle magic hat trick! "Face/Move" Offset!... and add "0.050".. (hot damn!)
Please send all money saved to: Paul Salvador (image/files attached)
Yay! Thank you heaps! I knew there had to be a way to address it! Now I can use configurations and equations, thus to achieve real-looking bowline knots from variously angled guy lines reaching from 22 feet up to 60 feet at the top, with no rope seeming to pass through the solid body of a guy ring. If you have a PayPal account, shoot me (privately) your email address. Mine's been posted on-line since 2002: gan@starling.us
Gan,.. glad it worked out! Sweep has always been weak and a pita, imho.
Sure, yeah, I'll pm you with my info.. very nice of you, thanks!
BTW,.. one thing to note or keep in mind when doing this.. is checking the "Minimum Radius of Curvature" (mroc) on the sweep,.. in the parts shown, both work fine but, to let you know.. the mroc and offset came close for the SS file,.. or within SWx error limits?... so, check the mroc so you know what Profile Dia you can use and/or the correct value for Face/Move/Offset.
For instance.. (the SS file).. the image attached again uses the profile 0.0875 for Sweep3 and the mroc is at 0.043.. although the Face/Move 0.050 offset worked (within SWx error limit).. ideally,.. the Profile for (SS) sweep3 should be increased to 0.100, thus increasing the mroc to 0.049.. so, the Face/Move/Offset of 0.04375 would be < the mroc.
And,.. there are times when things go wrong, and as you seee with the above example, and you can compromise to get the Sweep be small (clear the path), with a large mroc,.. and have the offset > the mroc.
Cheers and have a good weekend!
