When using hole series, how do I change direction of slot
Hi. I'm trying to use hole series where the end part is supposed to have a slot. The problem is that the slot is formed in the wrong direction. Is there a way to change the direction? I can't find any options for that.
SolidworksAssemblies
Answers 2
AR
AR 2015-12-21 Best Answer
You can change the direction by adding relations or dimensions to the center line.
you can drag the endpoint for free rotation.
comment imagecomment imagecomment imagecomment image
SF
SF 2015-12-21
Thanks. I must be doing something wrong then. If I use hole wizard the centerline appears and all is well, but with hole series there is no centerline in the slot. It's just a shaded preview.
