When double click dimension to change, SW shuts down
I click on the sketch under the feature in any of my saved part. I open the sketch and double click the dimension I want to change. As soon as I click, the Solidworks shuts down. If I single click, I can change the dimension from the window that opens on the left. However, if I double click it, the program closes. I encounter this problem not only in one part but with every part. Has anyone encountered this problem before? How can I solve this problem?
Solidworks Sketching
Answers 6
JS
JS 2021-04-29
This is most likely a problem with your graphics card driver.  To test this theory, open SOLIDWORKS and before opening any documents go to 'Tools....Options' and Select the 'Performance' category.  At the bottom, select the check box for 'Use software OpenGL'.  Then, open a part and try to change a dimension.  If it doesn't crash, the problem is definitely your graphics driver.
ES
ES 2021-04-29
Before this problem occurred it gave the following error. Then I uninstalled it and installed it again. The problem has not changed.
"Toolbar information is inconsistent, default toolbar setting will be used next startup"
ES
ES 2021-04-29
As you said, I selected "use software OpenGL" and the problem didn't change.
JS
JS 2021-04-29
If you close SOLIDWORKS normally after receiving that message, does it appear the next time you start SOLIDWORKS?
ES
ES 2021-04-29
We fixed the error by changing the registry file name. After this solution, solidworks opens normally, but does not allow editing the drawing or changing the dimension. The sw closes as soon as you click the dimension.
KC
KC 2021-04-30
Try a repair on your SolidWorks installation.
