What kind of fixtures should I use when I have a steel table against a concrete floor? The table have a weight of 500kg above it. So the 4 tubes at the table standing on should move.
I have struggled a long time now, to get to know what kind of fixture I should use if I have something on four legs against a floor.
When I look at examples they always use fixed geometry, but that is not true, all four legs can move. So how should I solve this?
If I use immovable it is not completly true either. I can only use roller/slider if it is a solid, and not a beam. But to do this calculation in a solid, it takes to much time, if it is even possible.
So then I come to use reference geometry in beam. Is that the "true" way to do it? And how should I set that up?
Thanks in advance
SolidworksSimulation
Answers 8
RN
RN 2021-04-08 Best Answer
You could add a contact set for "Virtual Wall" and define the four feet bottoms against a reference plane flush with the bottom that represents the ground. That would be the most realistic way at the expense of some solve time.
You may need to add some slight stabilizing fixture to prevent it from sliding side to side, or turn on "Use Soft Springs to Stabilize model"
Another option would be to create your own fixture using the "Remote Load/Displacement" tool. You can use this to create an 'immovable' style fixture even for solid mesh but it takes some more setup work.
JR
JR 2021-04-08
No, you can absolutely use beams. Just remember that the end of a beam has 6 DOF since it is a node and you must restrain them accordingly.
NH
NH 2021-04-08
Thank you all for trying to help me with this problem. As I understand it, you all think I need to use solidbody to solve it? Not beams? I know if I can use beams the calculation goes a lot faster. But that might not be possible then?
SY
SY 2021-04-08
Similar to the idea from Ryan Navarro ,Jim Riddell and Jim Riddell .
comment imagecomment image
JR
JR 2021-04-08
1-2SWNAAS wrote:
IMHO the best solution is to fix one of the legs and put roller/slider constraints on the other three. This allows them to 'spread'. When you check your reaction forces you will see a small force in x & y and expected forces in the z direction.
The other alternative is to only restrain in the z direction and use friction for the x & y.
JR
JR 2021-04-08
SM
SM 2021-04-08
Fix just one of the legs, or one node on one of the legs.
JN
JN 2021-04-08
Maybe use reference geometry and forbid translation along normal to the "floor" plane and allow only rotation on the normal of the floor plane (your own slider/roller).
And use symmetry (if model AND forces/fixture are symmetric of course).
