. i have modeled a forming tool with dimensions 1mm (L)x 1.8 mm(w) drafted with an angle of 15 degrees to a height of 0. 60 mm. then gave a fillet of 0.30 mm radii.... when i try to use it on my sheetmetal part having a thickness of 0. 30 mm i am getting this error: "The part's thickness may not be compatible with this form tool. The thickness must be less than the minimum radius of curvature for the form tool. " pls explain and suggest the modifications required...
SolidworksSheet Metal
What I'm seeing is that thickness and radii are the same sizes
Try with increasing the fillet radius
I just made a fast check, the radius must be greater than thickness.
thanks tateos
i changed the radii to 0.31 for forming tool... it worked on the base flange.. but is not working on the edge flanges...
It should work.
I'm using SW2014 and found some very strange behaviour, check attached part.
I hope that there'll be no problem with your forming tool, problem lies with the thickness of the part. Just reduce the thickness of part and check both'll works fine in a way that you requires.
Thanks and Regards
Venkatesh S
Application Engineer
E G S Computers India Pvt. Ltd.
http://www.egsindia.com | http://www.egs.co.in | http://www.egsindia.blogspot.in
I increased the radius at the top of the form tool to .305mm and it worked fine. I'm not sure what version you are using so I attached a 2015 file of the panel and form tool. Also an iges of the part.
I am using 2016 version as I increase the radii of forming tool to more then the bend radii that's 0.36 then its showing on edge flange ...
@dennis : in 2016 I am not able to do that on edge flanges(use 0.305)
my actual requirement is use a 0.3mm protrusion to arrest another 0.30 mm sheet metal cover with this one. but with a 0.30 mm height I would be unable to give the radii greater than 0.30
.. now I have made a louver (height 0.30mm)(2.6 mm L X 0.80 mm W) ..fillet 0.31 ..its working fine ... can any one comment on the manufacturing feasibility of this.
pfa attachéd model
