Hi
I have created an assembly with a weld bead feature. When I create a drawing of this assembly I can't see that weld bead feature. Is it possible to see this somehow on my drawing?
Thanks,
Paul
Hi
Thanks,
Paul
Paul,
Go to annotations>insert model items and in the property manager
in the second grouping below the dimensions there is a selection for weld beads.
Or you can just create the weld yourself as a seperate part if this symbology does not satisfy you.
It won't
you have to use insert > model item > caterpiller
We have requested solidworks to fix this as solidedge already drop the weld beads into the drawing.
Other thing you might be better of doing is creating the weld bead yourself by creating a new part in the assembly nd lofting or revolving or extruding the the welds. the the part inside the assembly and confiure the part to not show in the BOM
