I have a macro that a coworker wrote it worked fine, i went back to it a few days later and it is not completing its task. Its supposed to traverse through an assembly find all of the customer parts (in this case models with 256666 in the name, then run EditRebuild3. While it work when he saved it a few days ago, it is failing now. It traverses fine, fails on the EditRebuild3 on the qualifying models.
Option Explicit
Sub main()
Dim swConfigMgr As SldWorks.ConfigurationManager
Dim swAssy As SldWorks.AssemblyDoc
Dim swConf As SldWorks.Configuration
Dim swRootComp As SldWorks.Component2
Set swModel = swApp.ActiveDoc
Set swConfigMgr = swModel.ConfigurationManager
Set swConf = swConfigMgr.ActiveConfiguration
Set swRootComp = swConf.GetRootComponent3(True)
TraverseComponent swRootComp, 1
End Sub
Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
Dim vChildComp As Variant
Dim swChildComp As SldWorks.Component2
Dim swCompConfig As SldWorks.Configuration
Dim i As Long
Dim bRet As Boolean
Dim swCompModel As SldWorks.ModelDoc2
Dim boolstatus As Boolean
Dim Part As Object
Dim PartName As String
Set swCompModel = swComp.GetModelDoc2
If swCompModel.GetType() = swDocPART Then
'If swCompModel.GetType = swDocASSEMBLY Then
Debug.Print "Component: " & swComp.Name2
bRet = swComp.Select4(True, Nothing, True)
End If
vChildComp = swComp.GetChildren
For i = 0 To UBound(vChildComp)
Set swChildComp = vChildComp(i)
TraverseComponent swChildComp, nLevel + 1
If InStr(swChildComp.Name2, "256666") Then
'Debug.Print "Component: " & swChildComp.Name2
Set Part = swCompModel
PartName = swChildComp.Name2
boolstatus = Part.Extension.SelectByID2(PartName, "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
boolstatus = Part.EditRebuild3()
End If
Next i
swCompModel.ClearSelection2 True
End Sub
SolidworksApi macros
