VB Having trouble selecting individual points on a edge. Start and End points come back same after ModeltoViewTransform.
When converting Model Edge Start and End points, how come I am getting the same point in the view after converting using the View.ModeltoViewTransform.
The basic premise of this is to select one of these points to dimension off of the point itself not the edge. For some reason after the "swModelViewPoint.MultiplyTransform(swViewXform)" it returns the exact same point even when "vPtData1" and "vPtData2" have different numbers (I usually find this happening when X1 = (negative double) and X2 = (positive same double)). This will be used for auto dimension of a virtual sharp to an edge point, and ordinate dimensions.
Any help at all would be very much appreciated! This issue is pressing so quick feedback would especially be welcome! Thank you!
Below the code is trying to select the start and end point of an edge, but returns the same point.
Here is the example code.
'xxxxxxxxx START xxxxxxxxx
        Dim myModel As ModelDoc2
        Dim myEdge as Edge
        Dim nPtData(2) As Double
        Dim swModelViewPoint As MathPoint
        Dim swViewXform As MathTransform
        ' THE MULTIPLIER
        swViewXform = myView.ModelToViewTransform
        ' GATHERING THE EDGE DATA
        Dim myEdgeStartVertex As Vertex = myEdge.IGetStartVertex
        Dim myEdgeEndVertex As Vertex = myEdge.IGetEndVertex
        Dim myEdgeStartPoints As Double() = myEdgeStartVertex.GetPoint()
        Dim myEdgeEndPoints As Double() =myEdgeEndVertex.GetPoint()
        ' BUILDING THE NEW VERTEX (this is actually redundant it is laid out different in my program)
        ' START POINTS
        nPtData(0) = myEdgeStartPoints(0)
        nPtData(1) = myEdgeStartPoints(1)
        nPtData(2) = myEdgeStartPoints(2)
        vPtData1 = nPtData
        ' END POINTS
        nPtData(0) = myEdgeEndPoints(0)
        nPtData(1) = myEdgeEndPoints(1)
        nPtData(2) = myEdgeEndPoints(2)
        vPtData2 = nPtData
        'CONVERTING AND  SELECTING POINT 1
        swModelViewPoint = swMathUtil.CreatePoint(vPtData1)
        swModelViewPoint = swModelViewPoint.MultiplyTransform(swViewXform)
        nPtData = swModelViewPoint.ArrayData
        boolstatus = myModel.Extension.SelectByID2("", "VERTEX", nPtData(0), nPtData(1), nPtData(2), True, 0, Nothing, 0)
        ' CONVERTING AND SELECTING POINT 2
        swModelViewPoint = swMathUtil.CreatePoint(vPtData2)
'xxxxxxxxx END xxxxxxxxx
SolidworksApi macros
