I have an issue I've run into now and I'm going to run into in the future, so i'm looking for a recovery solution for now and a front end solution for later.
The issue is as follows:
I've downloaded several .stp files from vendor websites that are themselves multi-part assemblies (glorified boxes and enclosures mostly). I saved each .stp file in different folders and have spent about a day making the modifications/additions I need to make to each assembly (accessories, mounting solutions etc.) I'm now ready to put these assemblies into my top level assembly.
When opening the .stp files, several parts were made. These parts were named 1, 2, 3, etc. When the first two assemblies are opened at the same time now, the first several parts have the same name, and whichever assembly was opened first takes precidence. What shows on the screen is a combination of the two assemblies with numerous assembly errors due to the completely different scale and shape.
Currently I'm wondering if there is a way to force solidworks to sperately reference two parts of the same name from different folders. If not, will changing the part names with "save as" without using "save as copy" break this connection (I know solidworks files tend to be mutable unless you say "save as copy")? I would like to avoid having to "save as copy" then use "replace components" for everything I did as this would be time consuming.
In the future, I would like a way to download and open .stp files without this problem occuring. Is there a way to force a new nameing system (e.g. add "box1" in front of the 1,2,3, etc. that are created)?
Thanks,
Seth
SolidworksImport export
for that you can use SolidWorks Explorer or Pack'n'Go to rename your files and maintain/update references appropriately. This really depends on how many files you need to update as to what I would pick... but about the best sure fire method is to open each sub assembly on it's own and do a pack'n'go to update to all new names. then move forward with all unique names to put into your top level assembly.
the preventative measure in the future is to not duplicate file names anywhere.
Thanks, Paul, Pack'n'Go saved me a lot of time. As for file naming in the future, solidworks was automatically generating names (1,2, etc.). On my most recent import, I selected "import multiple bodies as parts" and it seems to have retained the original part names the author used which solved my problem.
Seth
