I have created a SW model of a Clerget Rotary engine. My issue revolves around the mating structure I used. I used mostly concentric (lots of cylindrical components rotating around a fixed crankshaft) , and coincidence mates, with a few parallel and cam mates. While building the engine, I made sure I had as many fixed subassemblies as possible, and applied the movable mates toto the moving components in the final assembly. While assembling the engine, the model would periodically create an overdefined mate error which was often cured with a rebuild and save. In other cases the mates would break, and the model components would literally go all over the place.
My last rebuild went well (I rebuilt and saved the model after each component was mated) and everything went well untill the final cam mates overdefined the engine again. The cam mates for the pushrods have been giving me the most difficulty-should that have been tangent mates?
Now the engine is overdefined and can not move-even though the mates are where they should be. Some of the mates marked as overdefined are critical ones that hold the engine components together.
Your help in correcting my matingissues would be greatly appreciated.
Thanks
Claudio Forcolin
Technological Studies
Bayview SS
SolidworksAssemblies
Looks like you have a similar problem to what I've been having for a while ( https://forum.solidworks.com/message/221299#221299 for that discussion). There is something flawed in the software I believe, or something with how it interacts with the computer hardware or OS or something, I can't pin it down. I was able to get your model to no longer be over defined by suppressing all concentric mates in the top level assembly, then unsupressing, then ctrl-Q rebuilding. Saved, opened and closed it several times and no more problems. Try that and see if it works.
