UNDO Issues / File Reverting Issue! Please help...
Hi all,
I'm really hoping others have experienced this. I've had this happen on three separate occasions where I'm editing a part, and hit Ctrl + Z to undo a feature or edit I was toying with, only to have it suddenly CONTINUE to undo every step I've made since my last save-- which often can be several time-consuming features, thinking, "I'll avoid the 7-8min save wait time and just finish this LAST feature before saving..." (I know, I know, I should probably be saving more frequently, but that's not what this post is about). There's no way to stop it mid-stride, and once it has reverted the file to its original state, there's NO WAY to Ctrl + Y and redo to recover the work.
I'm absolutely amazed that a "feature" like this would even exist in the software, and can't find any logical benefit to reverting when you could do so much more quickly by simply re-opening the file without saving. Is it perhaps linked a certain number of Ctrl + Z's in a row (i.e., say I hit Ctrl + Z three times, it triggers a complete revert?)?
This is so highly frustrating and I can't seem to even pinpoint what it is I'm doing to trigger this.  Any ideas? Is there a way to turn this completely useless and destructive "feature" off as a part of the functioning User Interface?
Any help would be greatly appreciated!
--Sloan
SolidworksParts And Features
Answers 13
JB
JB 2013-11-26 Best Answer
I've never seen this... I would tend to look for keyboard (wireless?) malfunction or possibly some MS sticky keys accessibility option to see if it thinks you're holding down the Z for a long time.
SA
SA 2013-11-26
Thanks for the reply, though it's discouraging!
I'm on a laptop with a wireless mouse, but native keyboard.  I've never had this issue in any other software packages, or any issues with sticky keys, etc. in the past (you'd think the issue would show itself just about anywhere if that were happening; i.e., even in a word processor, etc.)? The first time I had this happen, I hadn't saved in about 45minutes, and it reverted every single action I'd done in that time period, ONE BY ONE! I couldn't stop it (via Esc.), short of forcing close (which I did the second time). Thankfully I was saved by Autosave, but the second time I wasn't so lucky as the Autosave was somehow corrupt and unusable. So incredibly frustrating...
Really hoping somebody out there has run into this! Maybe it's an odd driver thing, etc....?
Brutal...
GS
GS 2013-11-26
I can't explain why that's happening, but I suppose the obvious suggestion would be to use the Undo icon at the top of the screen instead of Ctrl+Z and see if it still happens.
SA
SA 2013-11-26
I appreciate the replies.  Certainly a logical solution! Ha, I'll do my best there, but as I'm sure you can relate, trying *not* to use the most common keyboard shortcut of any software package is easier said than done when you're on a role and have been using shortcuts for the better part of 20 years.. And again, it doesn't do it every time, so there'd be know verifiable way of really knowing-- short of just waiting a few months until it may/may not happen again, all the while having to "train" myself not to use the shortcut again...
I'll leave this thread open in the hopes that somebody might have stumbled upon this issue before, and perhaps it relating more to configuration/drivers/compatibility/etc.
I'm also going to reinstall basic keyboard/mouse/touchpad drivers on my laptop just as a precautionary measure..
SF
SF 2014-02-07
I had this issue once before and today my collegue experienced the same when I heard him cursing
It is extremely discouraging to see your complex features being undone and nothing you can do about it, if only there was a re-do button.
I have no explanation to this "bug", we are using SW2013 SP 4.
HB
HB 2014-06-09
This problem still exists in the 2014 SP3 version. I've also found that sometimes it happens when I discard a sketch. I just had it chain-undo a half hour of work. Not fatal, but certainly something that shouldn't even be an issue to start with! I don't think it has anything to do with hardware or drivers, it seems linked entirely to the buggy/terrible undo-redo functionality of solidworks.
SF
SF 2014-06-16
This has happened to me as well. I remember it being a problem since at least 2007 but it's probably been present since the beginning. It's not unique to SW though and I've not yet found a way to reproduce it in a controlled way. This may be a unviersal bug that we all have to put up with from time to time.
SF
SF 2014-07-11
I'm having the same issues..Did anybody figure out a solution to this problem?
CO
CO 2016-08-30
Just had this happen when deciding to "discard changes and exit sketch" in a new sketch I'd just made and never closed. About 10 steps reversed back to last save, I could watch them disappear in about a second and a half (2 reference planes gone, one other sketch gone).
I had a weird episode just before that, where I was trying to make the sketch first, not having selected a surface, SW would not recognize my attempt to select a face for the sketch.
I have had files revert to previous saves during crashes. This is reinforcing my theory that saves get queued up for write, there is a bit of a delay or some undo cache that hangs onto updates for a while before really writing them to the file. This is just a feeling more than anything.
RB
RB 2016-12-09
I Resolutely stand that this is, and should be, the #1, Top of the List, Imperative, Urgent and Paramount Bug Fix/Feature Add/Enhancement/Improvement that Dassault/SolidWorks can give to us Users/Customers/Patrons.
Please bookmark and vote for this Top Ten...
This was on the Top Ten list a couple of years ago. Let's get it twice as many votes as any other.
RB
RB 2018-01-12
It's now January 2018 and we have until 1/31/18 to vote for this year's Top Ten List. I will quote myself yet again...
Undo/Redo - Un-Limited/Un-Restricted
YH
YH 2023-10-19
i still have this problem in 2023, now I run solidworks on bootcamp on an Macbook, but every once in a while when I hit ctrl-z  everything undoes itself, not knowing what I did wrong, has anybody found a solution for this?
RM
RM 2026-07-15
It is 2026 and this is STILL happening to me. Unbelievable.
