Undo command is not working like it should
I am working it a drawing that is very large, and I am sure that I have Automatic Solve checked on. If I move a line within my sketch, and then try to undo it, using either the button under tools or the CRTL+Z command, and it will not return to its original position. However, I can put a dimension on that same line and change the dimension, and when I try to undo this, it will work fine, undoing the dimension change, and then the dimension itself. Attached is the file I am working with.
SolidworksUser Interface
Answers 2
GS
GS 2015-06-10 Best Answer
The answer you were given here: is about as good as it's going to get.  There is no need to submit the question three times in different categories.
JW
JW 2015-06-10
Actually, see for more complete details. I am locking this thread. In the future, please submit only one thread on a single topic, otherwise, it becomes impossible to track answers across multiple threads.
Thanks,
Jim
