Unable to rotate assembly door with hinge
I've reached a point where, after trial and error by removing mates, I'm on my knees, unable to figure out what the hell is happening here. Just a plain door with a hinge connected to a block of timber which I made fixed. Neither the door nor the hinge are fixed, but even so, I'm unable to rotate the door. The only way I have to rotate the door is to manually change the angle mate between the hinge's plates (suppressed now). The fun fact about this is that, by itself, the hinge plates move fine as a separate assembly.
I've had to literally create a new assembly to isolate both components (pics below) to make sure there are no other components affecting it.
The door is part of a bigger architectural project for a client of mine. I've used SW for over 7 years now and puzzled. Thxs for any help I can receive.
Answers 4
KC
KC 2025-09-07 Best Answer
The hinge, as an assembly itself, should freely rotate with all other degrees of freedom removed.
The simplest parent assembly method is to have an open and closed state, with a configuration for each in the hinge file and in the parent assembly, too, with the correct hinge config selected for the parent's config: Select Open config in parent and this enables the open config in the hinge.
But since you want free rotate: Add the angle limit mate to the hinge file, as Mr. Cusack stated, and in the parent assembly, right click the hinge in the tree and select Flexible. Unless patterned, each hinge will need to be set Flexible.
A subassembly is brought into a parent assembly fixed in in its last saved state and SW doesn't perform any mate resolution for the subassembly. It's just a fixed blob in the parent.
By enabling Flexible, the degrees of freedom in the subassembly must now be assessed in the parent and all remaining DOFs in the sub are now available in the parent.
SC
SC 2025-09-07
Hi Alberto, you mentioned an angle mate is required to be suppressed in order for the movement. Would a limit angle mate be more what your looking for here? It will mate both components together at the angle but still allow the desired freedom. https://help.solidworks.com/2022/english/SolidWorks/sldworks/t_Limit_Mates_SWassy.htm?format=P&value=
KC
KC 2025-09-07
"Is this a new feature of SW 2024 or has it always existed?"
Per SW Help, Flexible first appeared in SW2020.
Drop down the year listing, as things may change year-to-year, but you can see which year something first appears by the change in the year text format.
Prior to the feature existing, there are no (and wouldn't be) any Help links. But, once implemented, each year is linked to that year's help page (which may be the same as the previous year).
comment imagecomment image
KS
KS 2025-09-08
I think the InPlace mate might be to blame, that's a pretty special mate you only get when working top down.
